It is currently Sat Apr 18, 2015 9:36 pm
 Post subject: 2M Dyno Results - Hold on to your hats!
PostPosted: Wed Apr 10, 2013 11:23 am
Just in case anybody is wondering what a 2M (MS-45) is capable of, here you go. Just had the Weber jetted and tuned. Other than the Weber and an electronic points conversion, everything is stock.
 Post subject: Re: 2M Dyno Results - Hold on to your hats!
PostPosted: Wed Apr 10, 2013 4:45 pm
:tu: - I appreciate seeing dyno results for vintage iron.
PostPosted: Wed Apr 10, 2013 6:03 pm
Thanks for the post! What weber carb are you running and what jets did you end up with in the end?
PostPosted: Wed Apr 10, 2013 6:08 pm
That is freaking awesome. I'm guessing that this was at the back tires?
So I'm guessing my crown with the 4m is probably 83 hp lol
PostPosted: Thu Apr 11, 2013 6:28 am
awesome! so my 4M logically must make about twice that.
PostPosted: Thu Apr 11, 2013 6:58 am
I like your line of thought there!
PostPosted: Thu Apr 11, 2013 8:33 am
The carb is a 32/36 DGEV Electric Choke. The DynoShop did the tuning so I'm not sure what ended up in the final setup. They did mention they thought that carb might be a little small for the motor which made it a little tougher to tune. It runs awesome though and should be really good on gas.
PostPosted: Thu Apr 11, 2013 8:36 am
At the rear wheels! I was happy to see the dyno print out on the wall of the shop with a picture of the car. First Crown on the machine!
