It is currently Mon Jul 06, 2015 3:17 pm
 Post subject: RT40 Corona Questions
PostPosted: Thu Mar 14, 2013 11:53 am
Hey guys,
I have a few easy questions about RT40 Coronas, specifically 1968.
1. Will any 13 or 14 inch 4x114.3 wheel fit over the front drum brakes ok?
2. I searched and found that the stud/lug thread pitch is 12x1.5, same as a Corolla. Is this correct?
3. I don't need to worry about left hand thread on one side or anything do I?
Thanks!
 Post subject: Re: RT40 Corona Questions
PostPosted: Fri Mar 15, 2013 10:24 am
Most came stock with 13" steelies Clearing the drums with an aftermarket wheel shouldnt be an issue.
*2003 Acura RSX-S * 1972 Honda Z600 * 1971 Honda N600 * 1964 Daihatsu Hijet "Almost Extinct" *
*2-1994 "RHD" Daihatsu Hijets 4x4 * 1992 Daihatsu Hijet Jumbo * 1967 Impala * 1969 Toyota Corona *
PostPosted: Mon Apr 08, 2013 8:17 pm
with a little guard massaging and rolling you can get 16x7 on there ive had 14x8s on the back of one both scrubbed a little
and on the one im doing ATM i will put 15x9 and 15x11 (i would go 14s but my future brake probably wont let me)
if you wish to ditch the drums RT81 disks bolt straight on using the whole spindle assembly or you can modify early celica TA22 disks easily enough
also many early celica/corona/hilux/hiace parts are a direct replacement or bolt on upgrade
Once apon-a-time world famous Photochopper
http://zammothechoppa.deviantart.com/ : )
