It is currently Sat Jul 04, 2015 7:46 pm
 Post subject: Auto shifter knob swap
PostPosted: Thu Mar 14, 2013 2:45 am
Any suggestions for swapping out the woodgrain T shifter on a Cressida? It has the side button to select gears, not sure if it will be an easy swap...thanks.
 Post subject: Re: Auto shifter knob swap
PostPosted: Thu Mar 14, 2013 8:02 pm
Are you jus trying to swap the. Knob itself?
PostPosted: Fri Mar 15, 2013 7:53 am
I think it's held on with a allen screw.
PostPosted: Fri Mar 15, 2013 8:55 am
It's held on with a small allen bolt. I've taken mine off before, they are pretty straightforward. Only thing is to make sure that the plastic tab underneath, which controls the shift lock, doesn't get spun around while you to the change. If it gets turned around it apparently adjusts the shift lock. I did that to mine and getting it to shift into park was almost impossible, I had to take the knob back off and re-adjust it.
PostPosted: Fri Mar 15, 2013 1:17 pm
Thanks guys, sounds straight forward, never took off a auto/button knob before...what I wanted to know is what did you guys swap it with? I wanna keep it kinda retro, but move away from the 'T' look, maybe a top button? Thanks.
PostPosted: Fri Mar 15, 2013 2:15 pm
I actually didn't swap mine out, I only removed it to replace a damaged piece of the console. I'm keeping with an all classic look so to wood shifter works for what I'm after. What options are you looking at, specifically?
PostPosted: Fri Mar 15, 2013 5:10 pm
Aww thats the best part of the interior i think! they actually feature that shifter in the 1978 cressida add..
i have a framed one my wife got me lol. "the expensive toyota"
74 260Z, Paint, flares, still sorting out the rest
78 Cressida Paint and body done. 1JZ in work
78 Cressida New wheels, T3 suspension, fixing engine and for sale soon.
PostPosted: Fri Mar 15, 2013 10:08 pm
haha, yeah, the faux wood plastic does has an aire of richness! :D I'm gonna do a full kustom interior, so maybe a metalflake steering wheel and a ball shift knob with top button...maybe 8 ball?
PostPosted: Sat Mar 16, 2013 12:21 pm
I just put a 300mm bubble in my auto prelude.. I'm assuming it'd be about the same set up
PostPosted: Mon Mar 18, 2013 9:29 am
I saw a big dildo made into a shift knob at the roadster show yesterday.. I hope it was a girls car...
PostPosted: Mon Mar 18, 2013 12:12 pm
That would certainly make for some interesting rest stops..
PostPosted: Sun Oct 06, 2013 9:52 pm
Finally found an auto adapter to convert the side button to top push down. It had a huge brass threaded fitting, I guess for domestic ball knobs. Had to drill out and tap in a smaller metric for my tall crystal knob. The plunger had to be cut down as the adapter sat too high. The skinny threaded rod inside the chrome shifter shaft was wiggling, made worse by the heavy and tall knob. Several trips to the hardware store, found various nylon and plastic sleeves and caps...took some work, but I was able to stabilize the rod and adapter movement. Works great and looks much better than the old faux wood T handle.
