It is currently Thu Jul 02, 2015 11:18 am
 Post subject: MX63 Cressida clutch pedal options
PostPosted: Fri Mar 15, 2013 7:47 pm
I am gathering the parts to drop a W58 in to my automatic equipped MX63, I know that clutch pedals will fit out of other Cressidas and Supras of a similar year but beyond that I don't know what will and won't fit. Thanks for the help
 Post subject: Re: MX63 Cressida clutch pedal options
PostPosted: Sun Mar 17, 2013 7:49 am
I don't know about the MX6x chassis, but in the MX7x chassis the clutch pedal out of an AE86 drops right in. Might be easier to find than a 5 speed cressida. MA6x will work, but you have to do some fab work. MA70 will not work.
1985 MX72 soon to be...
PostPosted: Mon Mar 18, 2013 11:12 am
By far the most commonly available pedal to swap in is from a squareback celica or celica/supra. Any salvage yard will have several at any given time. I have done several auto to manual x6's, and am in Spokane if you have questions.
Isaac
PostPosted: Mon Mar 18, 2013 11:53 am
That would be great, I will PM you
PostPosted: Fri Mar 22, 2013 7:50 am
i have a clutch master and reservoir that have the bolt pattern you're looking for. came out of a fwd celica and the design allows it to clear the stuff in my x8 better. if you have clearance issues with the a60 master/reservoir lmk and you can have it cheap.
PostPosted: Fri Mar 22, 2013 12:26 pm
celica supra petal and clutch master worked in my x3..... i had to drill a hole in the firewall to get the second mounting location to work... i may try and find a better solution down the road but anything pre 80s up here is hard enough to find; yet alone an AE or cressida in a yard
mx32 2jz swap in progress
