It is currently Mon Jul 06, 2015 9:43 pm
 Post subject: Documentation of a TE37 to 7M-GTE Swap
PostPosted: Fri Mar 01, 2013 5:39 am
Originally started with a TC setup:
I will be swapping this:
into this:
I will document each step as I go along. The firewall has been notched 4" and the section has been boxed:
The original shifter has also been relocated to suit the R154
The car is plauged with a little rust so progress will be slow.
Before:
After:
Plans include:
rear-mounted radiator
3" SS exhaust
8.8 rear
4 link
T70 turbo
30 x 12 x 3 I/C mounted behind grill
expansion tank
modified oilpan
custom catch can
shaved bay
bigger injectors (not decided which yet)
aftermarket ecu (not decided which yet)
fuel cell ans external F/P
swirl pot
All welding and fabrication will be done by me.
 Post subject: Re: Documentation TE37 7M-GTE Swap
PostPosted: Fri Mar 01, 2013 7:31 am
suscribed to this awesome project!!!! :tu: :tu: :tu:
 Post subject: Re: 7M-GTE Swap to TE37 SR5
PostPosted: Sun May 25, 2014 4:13 am
UPDATE
The rust repair has gone well and completed:
Wiring at the start:
Completed this way:
ECU and engine electronics in passenger compartment:
Intercooler hotside piping done:
Downpipe done sometime ago:
Wilwood pedals and masters:
Small teaser:
http://s83.photobucket.com/user/strfabw ... 3.mp4.html
 Post subject: Re: Documentation of a TE37 to 7M-GTE Swap
PostPosted: Sun May 25, 2014 2:00 pm
This is pretty cool, where in Brooklyn are you located? Im local and would like to come check this out in person.
- Travis
Bunch of cars, All TEQ Branded.
PostPosted: Fri May 30, 2014 12:20 pm
I'm in Canarsie. I will pm you my number. I'm doing some work tomorrow so it will be a good time.
PostPosted: Sun Jun 01, 2014 8:18 am
Video:
https://vimeo.com/m/97045776
https://vimeo.com/m/97046884
PostPosted: Fri Sep 12, 2014 5:05 pm
JNC Fanatic
Where You At :tu: :td: :idea: :wink:
PostPosted: Thu Sep 18, 2014 8:09 am
nice job, but what did you do/are you going to do about the oil pump?
Users browsing this forum: Google [Bot] and 6 guests
