It is currently Sat Jul 04, 2015 3:13 am
 Post subject: Help carbs back firing
PostPosted: Fri Feb 22, 2013 2:31 am
Hi there is done had a bit of a search but can't find anything that helps me out. I recently purchased a toyota 4k and dropped it in my starlet. I'm having a problem. The car starts and idles fine but if I just step on the gas it's just backfires out the carby and exhaust. I can rev it up if I slowly take the revs up, but as soon as I try rev it up quickly it dies. I've checked timing and that's good. Any help appreciated.
Cheers
 Post subject: Re: Help carbs back firing
PostPosted: Fri Feb 22, 2013 4:48 pm
check the jets on the carb. might be starving for gas. bad fuel pump maybe psi might be low. put a psi gauge on the line to see if the fuel pump is working properly. Could it be the original pump is not pushing enough for the 4k.
PostPosted: Fri Feb 22, 2013 11:31 pm
Check ignition timing, and vacuum timing advance system.
