It is currently Tue May 21, 2013 6:07 am
 Post subject: Need New Transmission Drain Plug
PostPosted: Tue Feb 19, 2013 2:04 pm
While rebuilding the drive train on my 74 TE27, I decided to clean up the T50 transmission. However, the drain plug stripped out on it, and it required that I use a Craftsman extractor tool to get it out. I finally got it, but the head is pretty cut up now. I assume all T-type transmissions (and maybe others?) used the same plug bolt. Does anyone have one lying around they are willing to part with? I will of course pay shipping, as well as a fair price for the plug.
 Post subject: Re: Need New Transmission Drain Plug
PostPosted: Wed Feb 20, 2013 12:13 am
I have one it should work it from a 1980 t50. let me go and pull it and get some measurements just to be sure.
PostPosted: Wed Feb 20, 2013 7:13 am
try rockauto.com I found a couple things there for my 71 corona, so I'm pretty sure they will have small stuff like this for the more known models.
PostPosted: Wed Feb 20, 2013 7:14 am
PostPosted: Wed Feb 20, 2013 6:47 pm
Forgot about Rock Auto...they were the only place I could find e-brake cables. Unfortunately, I haven't been able to find a drain plug.
Shane, let me know if you find one!
PostPosted: Thu Feb 21, 2013 12:45 am
You said it was the drain plug?
PostPosted: Mon Mar 18, 2013 12:51 am
Bump for an honest and straightforward guy! Thanks a ton to Shane for the drain plug!
