It is currently Tue May 21, 2013 6:57 am
 Post subject: 1977 TE51 windshield seal help! PLEASE!
PostPosted: Mon Jan 21, 2013 1:10 pm
Hello everyone, new to the board. I have searched the web for months trying to replace the windshield seals on both the rear and front glass of my 1977 TE51 (liftback). I hear that the front rubbers are available but the rear is not. If anyone here has replaced the rubber seals I'd REALLY appreciate hearing how and where I can buy seal replacements. This is all I need to get my Corolla back on the road. Someone please help my baby ride again. Thanks
Owner:
1977 Toyota Corolla Liftback
1976 Toyota Corona Wagon
1976 Plymouth Arrow
 Post subject: Re: 1977 TE51 windshield seal help! PLEASE!
PostPosted: Mon Jan 21, 2013 4:53 pm
Hey. It is possible to make a seal based on generic lengths. It depends on the profile, and a scan of that can then be used to match off the shelf lengths. Cut, and butt-glued, these can be used.
There are a number of generic old car rubber supplier on the internet. I used Scott's Old Auto Rubber with particular success for example.
Failing that, how bad is your old seal? Is it still in the car? A good caulk with the right flexible seal might assist?
http://www.ebay.com/itm/INDASA-Windscreen-Sealant-Window-Sunroof-Cluster-Leak-Repair-Sealer-Black-/290841249612?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D5041904110237090378%26pid%3D100011%26prg%3D1005%26rk%3D1%26sd%3D390514852349%26
Good luck! Neko.
The Black Cat - S800M Coupe.
PostPosted: Wed Jan 30, 2013 2:37 pm
Toyota org. part number
Front weaterstrip 56121-12180
Rear weaterstrip 68291-12010
Ask lokal Toyota diler or find http://www.ebay.com
PostPosted: Wed Jan 30, 2013 3:05 pm
http://www.toyotapartszone.com/oem/toyo ... 12180.html
http://www.toyotaonderdelen.nl/rubber-19273.html
http://www.oae-avto.ru/index.php?route= ... _id=126246
PostPosted: Wed Jan 30, 2013 8:37 pm
You wont find either front or rear glass seals for a TE51. :td:
Buy repo. oversees ke50, ke55 and get in good with your local glass installer. :idea:
PostPosted: Thu Jan 31, 2013 10:29 am
yep xE3x and xE5x are some of the most unloved by suppliers. couldn't get $h!+ for my TE31 when I had one! sux..
Roads?....Where we're going, we don't need Roads.
PostPosted: Thu Jan 31, 2013 10:53 pm
Cody Did you sell your te31?
76 TE31 Corolla 2TC
PostPosted: Fri Feb 01, 2013 8:07 am
Yes, sold it to a fella down near Austin.
Users browsing this forum: Google [Bot], SM Hunter and 1 guest
