It is currently Sun Apr 26, 2015 12:39 pm
Post a new topicPost a reply Page 3 of 4   [ 71 posts ]
 Post subject: Re: Danish Corolla KE30 '78 @ 2TG build
PostPosted: Fri Dec 20, 2013 4:42 am
Like the Project 8)
Here`s the differences in measurements of ke3 and te3 engine crossmembers if needed
http://imageshack.us/f/851/e3crossmember.jpg/
You may have noticed that you can use the K40 crossmember on the t50
Just use the boltholes 10cm further aft
PostPosted: Fri Dec 20, 2013 10:08 am
Thanks for the tricks...
I have seen the boltholes further back :-)
I Will make the changes in the engine mounts in sted of on the crossmember, because I have to change the angle anyway :-)
KustomS - Toyota Classics Spareparts...
'78 Corolla KE30 & '69 Crown Ute
PostPosted: Fri Dec 27, 2013 1:51 pm
Changing the cable clutch to hydraulic clutch
Now i need to "stretch" the pedal length and fit the KE70 booster.
PostPosted: Sat Jan 18, 2014 5:07 am
A little Update:
Before:
After:
PostPosted: Sun Feb 16, 2014 8:42 pm
Very cool ke30 :tu:
PostPosted: Tue Feb 18, 2014 11:28 am
Thanks for the thumbs UP :D
KE70 brake booster is now fitted and the old steering box and arms are removed.
Because of no bearing at the Bolton end of The steering column, I had to use a donor KE70 steering column and the customize the "gasket plate" connecting THE column to The firewall, here is the result:
Now I am ready to fit the modyfied crossmember With rack'n'pinion :)
PostPosted: Wed Feb 19, 2014 2:27 pm
Arrived today from Scotland.
Master cylinder upgrade.
Mitsubishi Pajero/Shogun 15/16" MC
PostPosted: Sat Mar 15, 2014 4:47 pm
A little Update.
Cleaning of the engine Bay, preparing for a new colour, haven't decided yet.
PostPosted: Sun Mar 16, 2014 2:36 pm
Just arrived today, ported and polished Valvehead.
Ready for final adjustments 8)
PostPosted: Sun Mar 23, 2014 12:02 pm
Got A little closer to the goal.
PostPosted: Sun Mar 23, 2014 12:50 pm
Exciting! Looks good
kolxoz
PostPosted: Sun Mar 23, 2014 6:37 pm
Does indeed look great! Bet you can't wait to crank up that lovely little 2T-G...
Is it a stock engine or have you played around with it a little?
PostPosted: Mon Mar 24, 2014 11:44 am
Valve head is flowed, the flywheel is lightened from 10kg to 7,8kg, crank, flywheel and clutch is balanced, Pistons and rods are weight balanced, ignition is optimized and all ports are flowed/grinded to match the gaskets for best possible flow :-)
I can't wait to fire it up 8)
PostPosted: Mon Mar 24, 2014 12:26 pm
Update :D
PostPosted: Fri Apr 18, 2014 2:44 pm
Next step:
Gearbox check :lol:
Syncro's okay, but This clip was wasted, new one ordered by Toyota.
Ready for takeoff :D
PostPosted: Sat May 31, 2014 2:38 pm
Looking good - looks like the work of a man that understands the mechanics of Toyota.
/ Per
PostPosted: Sun Jun 01, 2014 2:14 pm
Thanks... Taking it step by step...
New clutch, 200mm instead of 190mm OEM
PostPosted: Sun Jun 01, 2014 2:16 pm
RS56 donorcar for my Pick-up...
PostPosted: Wed Jun 04, 2014 2:02 pm
I know somebody that is in the Market for a station wagon or ute. Dó you know if there are any around here in DK?
PostPosted: Tue Jun 10, 2014 7:55 am
There has been a Crown wagon for sale in eskebjerg, but I don't know Any at the moment...
Text me. +4560130739
