It is currently Sat May 30, 2015 3:49 am
Post a new topicPost a reply Page 1 of 4   [ 71 posts ]
Go to page 1, 2, 3, 4  Next
 Post subject: Danish Corolla KE30 @ 2TG / Crown Ute / RA28 Celica build
PostPosted: Wed Jan 02, 2013 1:14 pm
Here is some info and a link to some pics of my old lady.
3K-H powered (for now) lowered 150mm in front and 110 in the back.
AE86 shorted struts with T3 camber plate and T3 Bump steer spacers.
In the back, I am doing a AE86 axle for disc brake and lsd :-)
Engine upgrade is on its way, I am rebuilding a 2TG and I am searching for the uppe chain slipper.
Rack'n'pinion crossmember is also created as an upgrade.
Enjoy and ask:
http://www.bilgalleri.dk/galleri/90617-toyota_corolla_ke30
Rebuild Mikuni SOlex for my 2TG:
And a rebuild alternator :
KustomS - Toyota Classics Spareparts...
'78 Corolla KE30 & '69 Crown Ute
 Post subject: Re: Danish Corolla KE30 '78
PostPosted: Wed Jan 02, 2013 10:11 pm
JNC Fanatic
great pics :tu:
2tg parts -- www.rinkya.com :idea:
PostPosted: Thu Jan 03, 2013 10:01 am
:tu: looks like good project :tu:
...................... My Project
Corolla KE35 1976
Celica GT RA40 1981
Celica ST TA40 1979
Carina Station wagon 1997
Carina sedan 1996
http://www.jdmwheels.cz
PostPosted: Thu Jan 03, 2013 11:50 am
It is a good project, when I get the picture uploadto work, I will post some more pictures.
After this weekend I will also post some more pictures of an upcoming project 8)
PostPosted: Thu Jan 03, 2013 3:14 pm
JNC Fanatic
http://www.rinkya.com/
PostPosted: Fri Jan 04, 2013 6:06 am
I have no luck finding parts on rinkya.com, but if I keep searching I might get lucky :-)
PostPosted: Fri Jan 04, 2013 9:41 am
JNC Fanatic
https://www.rinkya.com/new/en/auction-f116143882
https://www.rinkya.com/new/en/auction-r97643528
PostPosted: Sun Jan 06, 2013 2:16 am
Thank You for the help, I found the same ones, but it is the tensioner I need the most (13559-88260), for the 13563-88220 I will make a kameari'ish one, with a roller :D
PostPosted: Tue Jan 08, 2013 1:48 pm
My new project... Crown Ute '69
http://www.bilgalleri.dk/fotoalbum/dive ... 56_pick_up
PostPosted: Fri Jan 11, 2013 4:49 am
And a couple of pics:
:D
 Post subject: Re: Danish Corolla KE30 '78 (Updated, with Pics)
PostPosted: Sun Feb 17, 2013 10:26 am
AE86 diff modded to fit leaf springs on my KE30. 8)
PostPosted: Sun Feb 17, 2013 10:29 am
JNC Fanatic
look like some beefy brackets. :tu:
PostPosted: Fri Mar 01, 2013 12:53 am
They are bought from a 4wd supplier, I guess that is why they are a bit heavy duty, but better safe than sorry :D
PostPosted: Wed Oct 09, 2013 2:19 pm
A little Update.
8)
PostPosted: Wed Oct 09, 2013 3:05 pm
Hej med dig!
Hvor i DK kommer du fra? :D
Nice result on the cam cover!! 8)
I'm sure I'll eventually get around to making mine that nice to. The crackle finish is just a great look, but I can't decide whether to go with black or red for mine...??
PostPosted: Wed Oct 09, 2013 3:19 pm
JNC Fanatic
:tu: Ya VHT hi temp wrinkle finish with 4-5 heavy wet coats under a heat lamp or oven baked. :idea:
PostPosted: Thu Oct 10, 2013 10:34 am
Or in front of the fire place in the workshop 8)
VHT makes a perfect result...
Black is original, red is for Honda's :D I want the original look, with a Little red twist in the DOHC text.
Jeg bor nær Slagelse på Sjælland... Holder Du til i Hong Kong som Din avatar siger?
PostPosted: Thu Oct 10, 2013 10:44 am
Used chain slipper, but the best I have so far...
PostPosted: Thu Oct 10, 2013 8:39 pm
your corolla is pretty sick- is the 2TG a hard engine to source parts for?
1977 "kenmeri" Skyline GC111
1st place "best skyline" jccs 2013
PostPosted: Sat Oct 12, 2013 4:05 pm
Some parts are easy to get, because they fit from a 2T, but finding parts for the chain drive and the cylinder head Can get complicated. Fx the chain slipper, which is lampist impossible to get... :oops:
Users browsing this forum: jgorman18, Yahoo [Bot] and 4 guests
