It is currently Fri May 24, 2013 12:32 pm
Post a new topicPost a reply Page 1 of 1   [ 20 posts ]
 Post subject: 1971 RT62 18RG Corona Mark II
PostPosted: Mon Mar 22, 2010 1:17 am
Hello all, been lurking here long enough thought I'd finally throw up one of my projects!
I had the opportunity to pick this car up for a Datsun 510 Wagon shell I had laying around. Supposedly the engine was seized, but otherwise the car was in really good condition. After getting the car home a goofing with it for a few hours, I was able to get the 18RC running great.
Even though the engine runs good, I will be putting my 18RG into the car, lowering it, some nice old school rims and who knows what else.
Here she is all loaded up and headed to her new home
Custom screwdriver to hold the choke closed! Hmmm not getting any fuel maybe
Pulled the jets out...the main jet was plugged up solid, so it was only getting fuel through the idle circut
Engine that will be going in the car
Overall...after real close inspection, car looks really solid with only some rust on the rear trunk lid :mrgreen:
I'm thinking this is going to make a great daily driver!!
Last edited by Garlic Cruton on Fri May 14, 2010 12:52 pm, edited 1 time in total.
PostPosted: Mon Mar 22, 2010 10:16 pm
Nice. This looks like the one that was for sale for a long time on craigslist... The 18RG will bolt up but the tranny mount may not match. I had to install a set of mounts on my frame rail and change out the driveshaft. oh wait a ,minute.... i installed an A40 with the 18RG in mine!
The throttle cable will work with some messing around. re route the temp sensor and call it a day!
NOT STOCK!
PostPosted: Fri Mar 26, 2010 8:43 am
What You should do is put that 18rg in an Old School Celica and refresh the stock Corona to it Old School VIP status. That would be pimp. Just my opinion. Could be wrong :)
PostPosted: Sun Mar 28, 2010 3:56 pm
this is gonna be sweet :D
PostPosted: Fri May 14, 2010 12:56 pm
Well after coming back from TORC I was extremely motivated to get of my bum and get some work done. I got the RG out of my 74' Celica and dropped into the Corona for a test fit. Engine mounts, shifter location were spot on but I will need to fab a transmission mount for the W-50 as its mount holes sit too far back for the stock mount.
I must say I love the way it looks on there...nothing better than a built 18RG in a 4 door Corona.....one of my good friends is extremely against the idea and thinks I should leave everything bone stock. I'm thinking lowered, celica supras, and some suspension upgrades, this will be a 4 door any Granny would love to drive!
After getting the tranny mount fabbed, the motor will be coming back out and the engine bay will be getting cleaned up and repainted.
Oh yeah and get the fuel system ran and installed - sorry bad iPhone pic
Hopefully I'll have everything cleaned, painted and installed by next week.....4 doors of fury coming soon!
PostPosted: Fri May 14, 2010 1:06 pm
yeah i like what you're doing 8)
did the 4dr ever come from the factory with a twin-cam?
PostPosted: Fri May 14, 2010 2:54 pm
Nothing I've seen or read would suggest the 4-doors' came with the twin-cam, but I'm not extremely knowledgeable on all things corona's :(
Heck finding information on this model at all has proved quite daunting, seems it's sort of a rare bird.
Here are some of the engine specs:
- fresh RG block bored to 92.5mm
- 304/304 HKS cams
- 92.5mm HKS high comp race pistons with new rings
- 250 head ported and polished
- new Ferrea OS stainless steel valves
- short intake manifold
- matched and rebuilt Weber 45 DCOE 13 sidedraft carbs
- balanced rods with APR bolts
- new crankshaft and bearings
- lightened flywheel with APR bolts
- new complete gasket kit installed
- new pilot and release bearings
- Centerforce dual friction clutch and pressure plate
PostPosted: Fri May 14, 2010 8:24 pm
No, only the GSS Hardtops. About time someone made one, me thinks. :D
PostPosted: Sat May 15, 2010 2:08 pm
- 304/304 HKS cams
Did you build the engine?
PostPosted: Sat May 15, 2010 9:27 pm
I can make a GSS knock off with the parts I have. I can start off with the GSL I got the other day. Unless you look for the RT-75, no one will know...
NOT STOCK!
PostPosted: Sat May 15, 2010 9:29 pm
Oh, by the way, I am liking this build. Please keep it simple and no huge 19 inch wheels or 10J wheel stretch tires. please. Simple, clean, lowered just enough is what makes it look good. I myself am gathering parts for a 72 4dr Corona build in the future.
NOT STOCK!
PostPosted: Sat May 15, 2010 10:36 pm
Well I spent the evening having a friend fab me a transmission mount, since the W-50 is a bit longer than the stock W-40 it required a whole new transmission mount. My good friend Cary of Cary's Automotive a few bays down from my shop, did all the fab work and I must say it turned out extremely nice. After some grinding a some powdercoating and it will be spot on!!
Oh and don't fret after all the fab work is done...the whole underside and suspension will be getting a lot of love.
PostPosted: Sat May 15, 2010 10:44 pm
That's what I was asking myself before I read this and I decided no. That's okay though, Nissan would. I like it! :tu:
There's something I like about the four door version... maybe the taillights.
PostPosted: Mon May 17, 2010 1:21 am
Nice! Good score.
There was a GSS for sale Down here only last year...unfortunately, I didn't find out about it until last week, so have no idea where it may have gone. Only a dozen or so in Australia.
No-one knows what an RT72 is, let alone an RT75...go nuts! :mrgreen:
PostPosted: Mon Sep 20, 2010 4:54 pm
I pulled the entire front suspension in order to refurbish everything up front, give it a good cleaning and some new paint since she could really use it. Might possibly even see about a rack-n-pinon conversion? Then I'll be stripping the rest of the engine bay and giving it a fresh repaint!
It's amazing how similar the front end is compared to venerable mustang II front end
<a href="http://s731.photobucket.com/albums/ww317/GarlicCruton/1971%20Toyota%20Corona/?action=view&current=DSCN0553.jpg" target="_blank"><img src="http://i731.photobucket.com/albums/ww317/GarlicCruton/1971%20Toyota%20Corona/DSCN0553.jpg" border="0" alt="Photobucket"></a>
<a href="http://s731.photobucket.com/albums/ww317/GarlicCruton/1971%20Toyota%20Corona/?action=view&current=DSCN0551.jpg" target="_blank"><img src="http://i731.photobucket.com/albums/ww317/GarlicCruton/1971%20Toyota%20Corona/DSCN0551.jpg" border="0" alt="Photobucket"></a>
<a href="http://s731.photobucket.com/albums/ww317/GarlicCruton/1971%20Toyota%20Corona/?action=view&current=DSCN0554.jpg" target="_blank"><img src="http://i731.photobucket.com/albums/ww317/GarlicCruton/1971%20Toyota%20Corona/DSCN0554.jpg" border="0" alt="Photobucket"></a>
PostPosted: Mon Sep 20, 2010 6:14 pm
Looks great! An interesting amalgam of old style shovel nose front and later RT80/81.
I can't see anything wrong with putting an 18RG in it. And that trans mount is a lesson in fabrication. Simple, strong and effective.
Nice work!
PostPosted: Mon Sep 20, 2010 8:48 pm
Very nice. I'm goin to do the same with my corrola when its comes to suspension, but I'm slam it and make it ride like its on rails.
77 TE51
PostPosted: Sun Oct 17, 2010 8:16 pm
ahhh double wishbone <3
keep us updated man
DomoArigato wrote:
this is how a project is suppose to be, no stress, no deadlines, but pure fun!
PostPosted: Mon Jan 10, 2011 12:42 am
any up dates?
 Post subject: Re: 1971 RT62 18RG Corona Mark II
PostPosted: Sat Dec 29, 2012 3:04 am
Check your PM :)
