It is currently Wed Jun 19, 2013 4:15 pm
 Post subject: 76 corolla alignment
PostPosted: Tue Dec 04, 2012 4:31 pm
Hello,
i have a 76 corolla sr5 and its eating tire really badly and i was hoping someone can direct me to how i can adjust it im more interested in how to adjust camber and no i dont have any camber plates. Any info would help thank you!
-charles
 Post subject: Re: 76 corolla alignment
PostPosted: Tue Dec 04, 2012 11:42 pm
charlesM3 wrote:
Hello,
-charles
Charles, Have you taken it to an alignment shop? best bet would to go and have it checked out.
PostPosted: Wed Dec 05, 2012 10:56 am
You can't adjust camber without camber plates or changing the length of the lower arm (cut and weld) or possibly slotting the lower arm bolt hole at the frame and using eccentric washers. On a stock strut, all you can change is caster and toe. Lately, I found out (on my Yaris), you can't even change caster... :(
If you do go to an alignment shop, run away if they start talking about bending the strut tube. Yes, quite a few years ago, I took my Celica into a Bear Alignment shop (used to be a big chain), and the guy actually started telling me how my camber was off so they would have to disassemble the strut and bend it to get camber back into spec. I never went back.
PostPosted: Wed Dec 05, 2012 11:14 pm
thanks for all the replies very helpful
PostPosted: Wed Dec 05, 2012 11:15 pm
Oracles wrote:
charlesM3 wrote:
Hello,
-charles
No i didnt take it to a alignment shop but jay from ranz pointed me in the right direction thanks
