It is currently Wed May 22, 2013 12:04 pm
 Post subject: Question:Dipstick Is Coming Out When Driving??
PostPosted: Sun Nov 25, 2012 2:27 pm
Got home after a drive popped the hood and oil everywhere,then noticed no dipstick its just gone. :(
OK may be my fault,put in a spare stick all good.Nope same thing,but this time stick was hung up on
hoses. :td:
Slighty modified 2TG,is this a symptom of a known or common problem?
Whit-- N.Y.
 Post subject: Re: Question:Dipstick Is Coming Out When Driving??
PostPosted: Sun Nov 25, 2012 2:56 pm
Crankcase is pressurizing with no relief, check Pcv, or however your crankcase breathes
PostPosted: Sun Nov 25, 2012 9:07 pm
Ya OK,I just got a hose from valve cover top down to the block breather under the intake,behind oil filter.Been this way for years.
Pretty straightforward basic setup.Is there something else I could check?
PostPosted: Sun Nov 25, 2012 9:15 pm
So it's recirculated not ventilated then it sounds like. It needs to vent somehow
And it maybe that now your engine is wearing and you have some blow by forming an now crankcase pressure is a problem
PostPosted: Sun Nov 25, 2012 9:24 pm
OK that all sounds about right.
I will vent the valve cover.
