It is currently Sat Apr 25, 2015 4:22 pm
 Post subject: Help needed on 1971 toyota crown brake master cylinder
PostPosted: Sat Nov 24, 2012 1:00 pm
I picked up a 71 MS55 a while back and when i started working on it i noticed the brake master cylinder is leaking from the rear seal (inside the car). I was wondering if any other toyotas would interchange parts, i went to see about getting a new one or a rebuilt kit but no luck. Any info on interchanging parts or where to get a new or rebuild would be appreciated.
1971 ms55 crown deluxe
2009 Subaru Legacy
1968 Chevy C10 custom pickup
 Post subject: Re: Help needed on 1971 toyota crown brake master cylinder
PostPosted: Sat Nov 24, 2012 2:23 pm
Partsgeek has one for $18?
http://www.partsgeek.com/gbproducts/MC/ ... PAodJz0AoQ
PostPosted: Sun Nov 25, 2012 1:06 am
Yeah they are available all over the place. I got one at napa! 12 bucks!
NOT STOCK!
PostPosted: Mon Dec 03, 2012 11:02 pm
All I can come up with is master cylinders up to '70, if those will work i will order one tomorrow ($15) just unsure on it working. robakun, do you know the NAPA part number, or can you look it up from when you bought it, if i have that i can go to my local NAPA and get one. I just want to get a new one so i can drive it some before the weather turns bad
2009 Subaru Legacy
PostPosted: Tue Dec 04, 2012 1:23 am
The 70 should work.
NOT STOCK!
PostPosted: Tue Dec 04, 2012 6:23 pm
Alright, just ordered it! hope it works so i can get it soon and on.
2009 Subaru Legacy
PostPosted: Tue Dec 04, 2012 7:44 pm
The MS55 is tricky because '71 is a split year. Early '71 is S5 Crown, late '71 is S6 Crown. So the large majority of parts you need will be from a '67-70 Crown. Most of the '71 parts will be S6 stuff (usually says '71-74).
Luckily for you, your car has the bigger S6 car's engine, but all the consumables should be the same as a '70. :tu:
PostPosted: Tue Dec 04, 2012 8:35 pm
Such a good thing to hear John! Other than the master cylinder this thing is ready to drive, until i start into modifying it :lol:
2009 Subaru Legacy
