It is currently Thu May 23, 2013 10:57 am
 Post subject: What is necessary for for a k series upright conversion?
PostPosted: Wed Nov 21, 2012 10:29 am
What all pieces are necessary? Obviously the mounts, but does any motor work need to be done? How would i go about swapping to a t50 tranny?
 Post subject: Re: What is necessary for for a k series upright conversion?
PostPosted: Thu Nov 22, 2012 5:18 am
Not as simple as you might think. Main issues are the lubrication system other than obvious engine and transmission mounts.
http://www.rollaclub.com/wiki/index.php ... nscription
To fit a T50 you need a K - T bellhousing. Difficult to source and expensive if the seller knows what it is. Then of course the appropriate tailshaft and diff.
PostPosted: Fri Nov 23, 2012 2:18 am
Can you modify a bell housing adapter but with the 4speed bell housing to a t50? Do i have to source the bell housing?
