It is currently Tue May 21, 2013 11:27 am
 Post subject: Steering box corolla ke30
PostPosted: Tue Nov 13, 2012 8:25 am
Someone can help me, how to adjust a steering box from an Toyota Corolla ke30 1976.
Thanks.
 Post subject: Re: Steering box corolla ke30
PostPosted: Sat Nov 17, 2012 12:39 pm
Thanks.
normally toyota did it like this:
between the shaft and the chassis you must find
a nut with a flat screew driver bolt type in the middle
loose the nut with a long type socket and then tight the bolt just in 90§ turns very slowly and comparing using the steering wheel.
YOU HAVE TO BE CAREFUL WITH THIS,YOU CAN BREAK AND DESTROY THE INTERNAL WITH TIME ,,IF YOU DONT KNOW WHAT YOU ARE DOING!!!!!!!!!!!!!!!!!!!!!
before you did this ,i recomend to chek the steering linkage and fix all the system if possible
after that ,,the adjusting should be small and not compromise the internal and the future of the car..
my price for the diagnosis and the telepatic troubleshooting is
a "thank you " from you or any other member that found this helpful.
:) :tu: :tu: :tu: :tu: :tu: :tu: :tu: :tu: :P
PostPosted: Sat Nov 17, 2012 3:02 pm
Thanks for the tip, i will try that.
Users browsing this forum: SM Hunter and 5 guests
