It is currently Sat May 18, 2013 3:42 am
 Post subject: 67 Toyota corona
PostPosted: Thu Oct 18, 2012 11:14 am
So i have a 1967 Toyota corona 4dr. Im looking to lower the car by cutting the front springs and installing some blocks in the rear.. here my question what size wheel and offset are you guys running on your car for a nice somewhat flush look without the rubbing. I was thinking about running 15x8.25 with a +25 offset with some 195/50/15 tires.. what do you guys think..
 Post subject: Re: 67 Toyota corona
PostPosted: Thu Oct 18, 2012 9:18 pm
i think i have seen one corona with the "flush" look but im not sure what size wheels hes running
i'm sure he's out here in california
PostPosted: Thu Oct 18, 2012 9:26 pm
PostPosted: Fri Oct 19, 2012 7:56 am
dude paint your rims red and put some whitewalls on looks awesome!!!
FARK EVERYTHING AND BECOME A PIRATE!!!!!!!!
Image Image Image Image Image
PostPosted: Sat Oct 27, 2012 9:41 am
If you move the rear bump stops in on the frame you can get another inch of rim under there in the rear, not sure what your ideas are. I am trying to keep the tires in the wheel well while getting as much tire as possible.
The factory backspacing is about 3.5 om a 5 inch wide rim...
I will be using 4.5 backspacing on an 8 inch rim...
so, 1 inch further under the car and 2 inches to fill the wheel well outwards.
In the front I plan on 4 inch backspacing on a 7 inch rim...should fit nicely...
Here are the rims I will be using, they build the rims to order so there is no guessing.
Motegi mr224
http://www.ultimatewheeltire.com/index. ... mr224.html
PostPosted: Sun Oct 28, 2012 9:37 am
i got 195/50/15 xxr 501 rims. im almost flush and 2.5 inches from the ground on yust cut springs
1980 corona 20r boso project
