It is currently Fri May 24, 2013 8:57 am
 Post subject: 1975 celica TA22
PostPosted: Mon Oct 01, 2012 4:53 am
Hey guys,
Though I'd finally start a thread about my first celica that I bought back in 2004.
Specs:
Year : 1975
Model : LT Celica
Chassis : TA22 (Australian Spec)
Motor : 2T-G (had it when I bought it)
Carburettor : Solex ADDH (from an Alpha Romeo)
G/Box : T50
DIff : Standard
Green one on the right
As it stands today
Fibre glass glove box insert from Nathan aka Riceburna (Toymods)
The interior is pretty standard
It became a storage compartment for a long time
I plan to keep it standard with the hub caps
This is what it looked like before I started stripping the paint
My plans for this car is to build it, drive it and keep it out of the garage as much as possible.
I've already started building the motor for it
Specs:
2T 09 block (I had to clearence the block to fit the 3T crank)
3T 78mm crank
3T rods (lightened)
3T 1.5mm ACL over size pistons
ARP head studs
Camtech 210* @ 0.050 camshaft with 110 LSA with .252" lift @ valve.
32/36 Weber
Agawa 4.2kg flywheel
RPM HD clutch kit
I'm up to the stage of match porting the head, intake and exhaust manifolds.
That's it for now, I should have more updates in a few weeks time.
 Post subject: Re: 1975 celica TA22
PostPosted: Mon Oct 01, 2012 3:50 pm
Sweet celica, my car is a garage queen, always broken :(
PostPosted: Mon Oct 01, 2012 5:19 pm
Welcome!
Love where you are going with your build, Im sure when its done you will cave in to some nicer wheels though :D (peer pressure)
1971 TE28 Corolla
1980 TE72 Corolla
1995 S14.5 240sx
2005 R6
