It is currently Sun May 19, 2013 8:51 pm
Post a new topicPost a reply Page 1 of 2   [ 28 posts ]
 Post subject: RA45 GT Celica with full on race beams
PostPosted: Sat Sep 22, 2012 5:39 pm
hi guys here is my ra45 gt with a full on race beams
last pic is how it is at the moment
weighs in total with steel cage etc 970 kilos
car has 310 mm rotors on front with ap4 spot calipers and 28mm thick vented
on the back are ap 4spots on on 20mm thick vented 280mm
 Post subject: Re: RA45 GT with full on race beams
PostPosted: Sun Sep 23, 2012 12:04 am
By God that engineed is a piece of art...
77 TE51
PostPosted: Sun Sep 23, 2012 12:25 pm
Nice car. How much hp are you getting out of that beams?
PostPosted: Sun Sep 23, 2012 12:50 pm
its making 204 kws at the back wheels at 9200 rpm
PostPosted: Sun Sep 23, 2012 6:05 pm
Are those cams as big as they look?
PostPosted: Sun Sep 23, 2012 10:30 pm
yes the inlet is 565 thou and the exhaust cam is 530 thou plus im still using some vvti and in the pics you can see it has 2 stage fuel injection going through my 50mm quad throttles
all of the inlet and quad throttles i have made same with the 2stage as well
also make ti retainers for the new valve springs for the steel valves that i use
the only thing that is not changed on this motor is the block and head
PostPosted: Mon Sep 24, 2012 9:54 pm
What strut/coilover setup are you using?
PostPosted: Mon Sep 24, 2012 11:17 pm
ra45 strut with a small 65 mm dia spring and using bilstein shocks
PostPosted: Tue Sep 25, 2012 6:03 am
I guess the better question is what are the rotors sourced from, and did you put any adapters to make the AP calipers fit on the strut?
PostPosted: Tue Sep 25, 2012 9:40 pm
front rotors are from a seirra cosworth race car ,and are from the rear end 28mm x315 as std ap rotor or harop rotor .
calipers are radial mount and uses a dog bone with alloy hat.
the rear of my car comes std with a 7.5 bango and has a alloy bracket bolted to the 3 axle bolts and rear calipers are lug mount,with another alloy hat bolted to the axle
PostPosted: Tue Sep 25, 2012 9:45 pm
pics of crank and pistons and rods
PostPosted: Fri Sep 28, 2012 12:22 pm
What sort of motor mounts and crossmember fabbing did you need to accomplish to facilitate dropping the BEAMS motor in??
KFD
PostPosted: Fri Sep 28, 2012 3:28 pm
bolted in a ta23 or ta40 crossmember in and used sa63 engine mounts
PostPosted: Thu Oct 04, 2012 4:04 pm
This thing is beast! :tu:
PostPosted: Sat Oct 06, 2012 5:56 pm
ok current pics of what it looks like at the moment and with both sets of te37/v as well
this is with the te37 normal wheels with 225 tyres on the back
 Post subject: Re: RA45 GT Celica with full on race beams
PostPosted: Fri Oct 19, 2012 8:45 am
i love the wideband bungs for each cylinder.. serious tuning.
PostPosted: Fri Oct 19, 2012 3:49 pm
as these are the beams race pipes with the slip on fittings i have 2 do every cylinder ,to either add fuel or take out fuel on the cylinder table on the motec set up
PostPosted: Sun Oct 21, 2012 9:23 am
This is incredible. I was looking at pictures of this very car online while I was looking for inspiration for my project! :D Glad to see it in greater detail, it just gets cooler by the minute. 8)
PostPosted: Tue Oct 23, 2012 8:20 am
nice car!!
great tuning for the race!!! :mrgreen:
PostPosted: Fri Oct 26, 2012 2:56 am
nice looking racer :tu:
Users browsing this forum: Me86Rob and 4 guests
