It is currently Tue May 21, 2013 7:54 pm
Post a new topicPost a reply Page 2 of 3   [ 42 posts ]
 Post subject: Re: Ryan's TE31
PostPosted: Mon Nov 05, 2012 7:29 pm
California smog is a PITA. My car runs smooth, but it is WAY too rich. At Idle the car passes with no problems, but once the RPM's go up CO goes up too high. Way too Rich off idle.
I am stuck with an aisan carb because there are no legal alternatives. Does anyone on here know how to tune the mixture for ranges above idle? If not, It looks like I will be paying $325 for a rebuild on an already rebuilt carb...
On a better note, I got to see the bottom of my car while it was on a lift. One of the many pics I took:
liftbackte51 wrote:
Nice build.
Do you know if they had more te51 parts at the junkyard?
I am looking for a dash with gauges and a pedal box from a manual
The car was gone the next time I went. I had the pedal assy. 1/2 way out.
palatine wrote:
Skellington wrote:
Oh-Yea, 1/2 off day at the parts yard:
Damn, that's a score..
I thought so too. 8)
PostPosted: Wed Nov 07, 2012 9:08 pm
there is one legal carb for these corollas
this is from the air resource board of cali website.
EO: D-133-10A View PDF
EO Date: 1986-07-14
Manufacturer Name: Redline, Inc.
Device: Weber
Device Type: Carburetor / Carburetor Modification
Part_Number: Model_Specification: Modification_Allowed: Remarks:
32/34 DFT 9A/11A 1974-1979 and earlier Toyota with a 2TC engine 1970-1974 Toyotas with an 8RC or 18RC engines. The fuel shut-off vacuum switch, throttle positioner or dashpot, throttle valve switch, throttle opener control system, altitude compensator, mixture ratio control valve, auxiliary accelerator pump, choke breaker, and secondary fuel cut solenoid, on vehicles so equipped, may be disconnected or removed.
weber 32/34 dft
1978 Corolla 2TC
PostPosted: Wed Nov 07, 2012 9:13 pm
also the doug thorley headers are smog legal for the 2TC :D
1978 Corolla 2TC
PostPosted: Tue Nov 13, 2012 4:27 am
I have the best wife ever. Look what she found and bought for me: Redline Weber 23/34DFT 9A
Its a CA smog legal, Weber carb. Its brand new in the original box! perfect condition will all hardware! I'm so excited i'm posting this at 3AM!
PostPosted: Tue Nov 13, 2012 1:13 pm
Awesome! Congrats. That is a sweet wife indeed. What's your secret?
PostPosted: Tue Nov 13, 2012 3:00 pm
Those 2T engines are some of the best ever made and the easiest to work on. Changing a head gasket takes an hour or less. I had a 1974 Carina with a 2T, back in the U.K. and had the carb in peices on the side of a road in Northern France. Put back together (wasn't the issue) in minutes and found the problem anyway.
Not sure about the smog requirements but good luck with the Corolla
PostPosted: Tue Nov 13, 2012 3:14 pm
I love the 2t engine so far. From what I hear, the weber carb is a really good one. I need an adapter and I should be good to go. I kinda wish I could learn how to adjust the richness of the aisan carb above idle because I have access to a complete TE51 liftback that has been sitting for years.
PostPosted: Wed Nov 14, 2012 7:13 am
thats awesome! i wasnt able to find any of those carbs online. do you if there are more from where you got that one?
1978 Corolla 2TC
PostPosted: Wed Nov 14, 2012 12:25 pm
sadly, no. I happen to get one that had sat on a shelf since 1983. The box had dust on it, but everything inside was mint condition. The kit was missing the adapter though, so it looks like I'm going to have to make one. If you need to pass CA smog... you can always get a newer Weber and grind the ID smooth, then use a letter punch kit and punch the info from this one. :lol: I doubt anyone in a smog shop would know the difference.
PostPosted: Wed Nov 14, 2012 12:42 pm
i like the way you think :twisted:
im not due till next year
1978 Corolla 2TC
PostPosted: Mon Nov 26, 2012 12:01 am
Here is what I am working on:
http://japanesenostalgiccar.com/forum/viewtopic.php?f=9&t=21035
PostPosted: Tue Nov 27, 2012 1:49 am
I started the spacer to make my weber fit. Pics will explain best:
This is the plan:
Cut 6011 alum. with bandsaw:
Drill holes with drill press. Here I am pilot drilling with a smaller bit to keep the holes aligned.
IT FITS!
Mocked up:
Plenty of space in back:
I rounded the edges. I would like to make this look as if it came from the factory when its done.
I drilled the front 2 holes of the carb so they now fit the wide pattern, and it aligns the ports as close as I can get them to the stock manifold. Next I will drill the middle narrow holes and thread them for studs. Then I will drill the 2 ports and make them match the weber's to the manifold's.
PostPosted: Tue Nov 27, 2012 6:49 am
Good choice on the spacer. The old toyota cast isn't that terrible, but it's still old, oil-soaked cast that is a pain to weld clean.
Those renderings look familiar. What 3d modeling software did you use? :lol:
PostPosted: Tue Nov 27, 2012 1:33 pm
Agreed. I think this way is more stright forward and it will be clean.
BWAHAHAHAH -its ms paint :lol:
PostPosted: Mon Dec 17, 2012 12:34 am
I was not happy with the progress on my spacer. I had a bad plan on how to do the middle large holes. After working on it for a while, I realized that I can make another one for less time than it would be done, and it would be a cleaner job. So in a very short time I made one. I like the way this one lines up better than the old.
This one got a little beat up while trying to get the middle of the big holes out:
Lets just try again:
There we go. Nice and clean:
I hope to have this weber on the car soon. I have temp. registration on my car till January.
PostPosted: Mon Dec 17, 2012 8:29 pm
good luck! keep the updates coming
1978 Corolla 2TC
PostPosted: Mon Jan 07, 2013 11:38 am
It has 38k original (non rolled over) miles.
Those must have been some rough 38,000 miles.
PostPosted: Mon Jan 07, 2013 1:11 pm
Nice job on the adapter plate so far, your MS Paint drawing made me feel like a hack, lol. I went to school for that and I'd be lost without Autodesk Inventor or Solidworks.
PostPosted: Tue Jan 08, 2013 5:14 am
Nice project mate!
1975 C110 Skyline Coupe
PostPosted: Sun Jan 20, 2013 3:03 pm
-Thanks guys
Things are slow going with my car as I am prepping my house for sale. I have installed the Weber carb. I had to make the adapter from previous posts, and a throttle sinkage setup. Here they are on the car and a video of it running like a tractor. Enjoy:
Made these:
Installed:
All buttoned up with the air cleaner on:
Running like a sick tractor until i get it tuned:
Users browsing this forum: Google [Bot], TPR Motorsports and 7 guests
