It is currently Wed Jun 19, 2013 6:53 pm
 Post subject: 4ac with k50 trans?
PostPosted: Wed Jul 18, 2012 3:30 pm
So I have a 77 corolla ke30 with a blown engine, I recently came across a 4ac for dirt cheap and I was wondering is there is any way to easily bolt the 4ac to my stock k50 tranny.
Any info on putting a 4ac into amy ke30 would be awesome!
Thanks
-Jason
 Post subject: Re: 4ac with k50 trans?
PostPosted: Fri Aug 03, 2012 7:16 am
The only way to do this would be to find a K50 from a AE85 that was only available in japan... the K tranny doesn't have a removable bellhousing and K engine bolt pattern is different from A engine.
On a good side, a T50 tranny from a TE2x, TE3x TE5x, etc will accept your stock driveshaft, same output spline count, same dia and same tranny length... and it will bolt behind a 4A bellhousing with minor modification (but you need a 4A-C manual bellhousing to pull that one off...
Or you could get a whole 4A with it's T50 tranny but you'd have to cut the transtunnel a little to accomodate the shifter that sits a couple of inch backwards and you'd have to swap the driveshaft yoke for an AE86 22 spline yoke... but overall length is the same.
Hope that helps you.
Users browsing this forum: Mazota TE51 and 4 guests
