It is currently Tue Jun 18, 2013 11:03 pm
 Post subject: 3sg starter
PostPosted: Mon Jun 18, 2012 11:35 am
In the middle of a transplant and was wondering if anyone knows which starter to use?
I have a 3sgte 2nd gen with a 2s bellhousing going into a te27, but was not sure which starter to use. I plan on using a 91-95 MR2 turbo flywheel. Mr2 have starters on tranny side so tgey wont work. Any suggestions are appreciated. Thanks..
 Post subject: Re: 3sg starter
PostPosted: Tue Jun 19, 2012 2:41 am
you need a 2s starter and altezza 3sge rwd fly wheel for it all to work fwd flywheel wont work .clutch fork has to move to much
PostPosted: Tue Jun 19, 2012 9:14 am
Now where would one find a 3sg rwd flywheel? Or is there something here in U.S that I can use.....3sfe maybe???
PostPosted: Tue Jun 19, 2012 12:54 pm
i have a 3sge beams cusco super single here fly wheel clutch etc looking for 900 aussie plus postage
PostPosted: Mon Jul 02, 2012 7:09 am
1986-1989 celica gts (usdm) starter rests under the exhaust manifold - not over the transmission.
that setup uses the 3sge and 5sfe flywheel, so your options are as such.
5sfe flywheel: 225mm
3sgte flywheel: 236mm
so... if you do not already have the 3sgte flywheel, you could use the 3sge/5sfe (225mm) flywheel with an upgraded clutch kit and the above mentioned 1986-1989 celica gts starter.
PostPosted: Thu Jul 05, 2012 2:47 pm
Thanks for the info...I will try that setup...
Users browsing this forum: burgggie99, Doraiba and 2 guests
