It is currently Wed Jun 19, 2013 11:31 am
Post a new topicPost a reply Page 1 of 1   [ 20 posts ]
 Post subject: 78 Cressida MX32 - L28 turbo daily driver
PostPosted: Tue May 29, 2012 11:11 pm
Hey guys. New to the forum and just thought I'd share my current project with the nostalgic community!
Picked up this driving 78 Cressida beauty for $700.
Then I did what we all do to achieve quick lowness status, cut the springs.
Threw on some 15x9 -15 shokotans.....
4AM commute 57 miles one way to work on I90 :lol:
Ride was complete garbage and I wanted to go lower, so I decided to do something a little more legit. Up front: T3 weld on coilover kit, T3 camber plates, shortened front strut tubes, agx short stroke struts. Rear: Camaro short stroke shocks, some old race car springs cut down to fit, and T3 lateral bar.
Turned out pretty decent and drove it around for a few weeks.......
 Post subject: Re: 78 MX32 L28et daily driver
PostPosted: Tue May 29, 2012 11:45 pm
Shortly thereafter.......Engine started to lose power and drive like crap. Pulled off the intake to find a large amount of exhaust air coming back out through the carb! Not good! So, not knowing what the hell I was going to do I decided to pull the engine and go from there. I had a spare 4me shortblack sitting at home anyway so I figured I could make something work.
Pulled engine, and started dis-assembly. Found blown headgasket (feeling awesome), and figured I'd do a quick rebuild. Well that was shortly lived as I disovered the head was cracked in between the exhaust and intake valves in every cylinder! Damn! Now whaaaaaaaaaaaaaaaaaaaaaaat?
Car sat for a bout a month or so until I could decide what I wanted to do with it. I really wanted to keep the engine old school and of the same generation. Something about a 2jz swap just didn't seem like the right thing to do.......
A buddy of mine had been sitting on this old l28et engine for 5 years and I finally talked him into getting rid of it. So, we have a winner! L28et it is! I realize the thing is dirty as all hell, but that is what im going for! I'm going back to the old days of making things with what i got and keeping the cost down! There is so much more character and story to an old dirty car......
Picked up the engine and started messing around with getting it in the car.......Quickly realized oil pan was a no go so I flipped it (temporarily) with two bolts holding it up and started making mounts. Made a cross bar support for engine bay since my POS cherry picker hydraulic cylinder leaks and continues to drop the engine.
Motor mounts made out of some flat stock I had laying around. Ended extending stock motor mount pad on crossmember forward a few inches, using the stock 4me rubber mounts and making the engine side angled pieces. Turned out pretty good and sits pretty damn solid.
From below...
Reworked stock trans mount. Cut in two places, tweaked a bit, and rewelded......
Once all of the mounts were finished, I decided to yank the engine back out to finish all the other issues....
First plan with oil pan was to just simply cut the sump out and rework it to the front. However, after doing some digging I found out the 82 Maxima's with L24 engine used a front sump pan. I was pretty pumped and ended up finding one at a local junkyard for $30! SCORE!
Started messing with oil pickup options and pan fitment.....
Ended up using stock oil pickup ends, and added some tubing to angle it toward to the front.
Next issue was obvsiously all the other oil pan items............turbo drain, oil temp sensor, baffles, dipstick, etc......
Modified oil baffle to fit around new oil pickup
Random pipe fitting I had laying around for turbo oil drain
Raped stock oil pan for oil temp sensor fitting and welded it in. This was a well insertion type fitting and I could not find one anywhere...
I didn't want to drill into the block since I dont plan to rebuild it right away, so the next best option was to use a generic dipstick kit and do work.
Made a quick EGR blockoff plate while engine was out.....
Remounted all the other BS. Had to modify alternator mount a bit since I chose to use 3 mounting holes for moter mounts instead of 2. Also running a L24 fan since it's offset and closer to engine. This was necessary to utilize stock radiator and shroud. All ready for the permanent home!
PostPosted: Wed May 30, 2012 12:20 am
Got her in and started messsing with wiring. I really want to keep the thing as OG as possible so standalone is not an option. However, these old EFI engine are a major PITA for wiring!
Started breaking down the entire 280zx turbo harness......
Ended up with just what I needed, Engine harness alone.
Now time for damn 3rd pedal.....Ended up using the clutch master cylinder and pedal from the 280zx and modifying to fit.
I really want to use the stock 280zx gauges(electronic boost, oil temp/pressure, and clock) but placement is farely limited. Thinking about going with this route.....
PostPosted: Wed May 30, 2012 12:24 am
Well that is basically all for now. I am just about finished with all the wiring. Really all that is left to do is to figure out fuel delivery options, get a driveshaft made, and perhaps an OEM intercooler of some sort since these bad boys were hot-piped.
I will try to update this thread atleast weekly. :)
Let me know what you think?
 Post subject: Re: 78 Cressida MX32 - L28 turbo daily driver
PostPosted: Wed May 30, 2012 4:57 am
that is pure awesome :tu: just a note the diesel maxima pans have an oil return already... i have one laying around for an l28et build i gave up on.
what did you do for the dipstick> tap the block?
mx32 2jz swap in progress
PostPosted: Wed May 30, 2012 1:12 pm
Awesome car!
Man, I'm so close to pulling the trigger on a set of those Rotas for the 'Rona...
PostPosted: Wed May 30, 2012 1:55 pm
Man, this thing is awesome!
PostPosted: Wed May 30, 2012 1:58 pm
Awesome! Makes me miss my mx32 :(
PostPosted: Wed May 30, 2012 3:37 pm
schassisowner wrote:
that is pure awesome :tu: just a note the diesel maxima pans have an oil return already... i have one laying around for an l28et build i gave up on. what did you do for the dipstick> tap the block?
I ended up using a generic dipstick and welding some 1/2 tubing directly into side of oil pan (similar to a lot of old v8's).
BeanBone wrote:
Awesome car!
Ya I couldn't beat them for the price! I figured they'd do the job for now. Size is about perfect. Figure if I get sick of them I can always paint or sell....
PostPosted: Wed May 30, 2012 7:58 pm
Interesting combo. This Cressy's the tits! :tu:
-'70 corona MKII wagon
-'80 rx7 racecar
^Heres my build thread^
Packergreg wrote:
Hezath wrote:
Wagons pull the bitches
PostPosted: Wed May 30, 2012 8:38 pm
i saw that after i posted lol
yupp i had mine set up like that too... never made it in my s13 though
PostPosted: Thu May 31, 2012 11:47 pm
:tu:
i like it.
1980 Cressida MX32
Old Series Garage
PostPosted: Sun Jun 03, 2012 8:04 pm
Love it...
+1 for WA :)
Must have meet
PostPosted: Mon Jun 04, 2012 9:39 am
Nice thread and clean cressy! :tu:
PostPosted: Mon Jun 04, 2012 4:12 pm
WA STATE FTW!!!!!!!!!
Not too much for updates, just getting all the wiring complete. Obviously wiring will be all cleaned up when finished....
As it sits right meow....
Running harness through old AC evap holes.....
Ecu plugs and fuel pump modulator. ECU will likely mount flush to firewall depending on space when all HVAC is mounted back up....
Terminal board for ecu/relay power and what not....mounted behind glove box.....
Decided to relocate my battery to the passenger side to give more room for turbo piping. Using a generic fuse panel for existing stock circuits and added EFI shit. Will just run a single wire over to battery to grab power....
Still piling up parts for fuel delivery and should have all that in this week. Also ordered an oem saab 9-3 intercooler since it has both inlet/outlet on one side :wink:
PostPosted: Mon Jun 04, 2012 4:21 pm
Also, recieved aftermarket 280zx turbo 2.5" downpipe. Will have to modify it to fit but its pretty damn close! Stock downpipe was rubbing on steering linkage.....
Also found a place for the 280zx turbo gauges. I'm going to cut a whole in the glove box.....
PostPosted: Sat Jun 09, 2012 10:43 am
Purists be damned, lol. This is awesome, love it :D
The L28's going to look so much more at home in there than a JZ as well, there's something not quite right about how a modern twincam engine looks in an older car.
'81 Scorpion- Daily thrasher/track project. 4G52, 4.6:1 rear end, suspension work etc.
'00 Magna- 6G74, 5spd. Sensible, reliable daily, gets along pretty well though.
'79 Suzuki GS550- 580cc overbore, rejetted carbs.
PostPosted: Wed Jun 13, 2012 4:51 am
Lovely project! Can't wait to L28 + Boost my Cedric. This is inspiring me more haha
^ This.
PostPosted: Sat Jun 23, 2012 8:52 pm
I have a 1980. Where can I get those struts, and where are they price wize? Could use the help. What did you do for the rear?
MANSUS
PostPosted: Mon Jun 25, 2012 8:55 pm
looks like way too much work but it IS awesome !!!
SPARKLE GARAGE
雷 - BANG !!!
Users browsing this forum: 76RA24 and 4 guests
