It is currently Sun May 26, 2013 12:31 am
 Post subject: 4M spark plug access
PostPosted: Wed May 16, 2012 4:53 pm
Posted this in my existing thread but couldn't get an answer do here it is again. The spark plug in cylinder 1 is blocked by a mount for the air pump on my Cressida. The angle is such that I can't get the socket into the tube. Even with the socket off the ratchet entirely, it simply won't fit. Can anyone tell me how to get at this spark plug?
Anyone needing a picture can find one in my thread
http://japanesenostalgiccar.com/forum/viewtopic.php?f=9&t=16396&start=20
 Post subject: Re: 4M spark plug access
PostPosted: Wed May 16, 2012 6:32 pm
2 bolts.. Remove the smog pump.. Remove the spark plug.
Welcome to my world.. That's why I got rid of the thing eIntirely.
PostPosted: Wed May 16, 2012 8:21 pm
^ the only answer you need. LOL!
1977 Celica coupe
1977 280z - wife's car
1955 Ford truck
PostPosted: Thu May 17, 2012 1:01 pm
Thanks guys. I guess that's what happens when you deal with a part that was added post-design. Any idea what size of belt I'm going to need when the pump is removed?
PostPosted: Thu May 17, 2012 2:37 pm
I actually had a bracket made to move the power steering pump to the other side of the engine.. So not sure. Your smog pump is your tensioner if I remember correctly so you would either need to add a tensioner pulley in its place or just remove it to get to your plug then put it back.
PostPosted: Thu May 17, 2012 5:38 pm
49" v-belt straight from the crank to PS pulley. Belt # 49017.
I grabbed a PS pump bracket from a 4ME or 5ME Cressida without the smog pump. The power steering pump will be the tensioner.
1977 Celica coupe
1955 Ford truck
PostPosted: Fri May 18, 2012 9:07 am
Awesome, thanks. I'll have to keep my eye out for a second gen cressida in the yard. Not sure what my chances will be, but we'll see.
