It is currently Sun Feb 01, 2015 4:01 pm
Post a new topicPost a reply Page 1 of 1   [ 14 posts ]
 Post subject: 78 Corona Bumper Removal pic/procedure request
PostPosted: Sun Apr 22, 2012 10:12 pm
Im trying to remove my rear bumper just to see how it would look. I'm liking the old school no bumper look but its a P.I.T.A. All the necessary bolts are removed but it feels like Im missing something, I see there are like rams pressed into the chassis, not sure if its just that old to where its near impossible to remove it but it should come out.
To the point, does anyone have a picture of a T100 corona without bumpers or has any input on how to do it?
 Post subject: Re: 78 Corona Bumper Removal pic/procedure request
PostPosted: Sun Apr 22, 2012 10:28 pm
there's is at least one guy here who's put later model plastic bumper/spoiler
and it looks real good
that could be an option?
-Matt
PostPosted: Sun Apr 22, 2012 10:42 pm
possibly but im REALLY leaning toward the bumperless, if it doesn't work out then I'll see from there. i guess i gotta search harder lol
PostPosted: Tue Apr 24, 2012 11:32 pm
you could do a tucked in bumper which what i did to mine or if you could find a jdm chome bumper would be way better. There is a guy from 1stgencelica and i believe he is called bullit on that forum. contact him if he has some rt bumpers.
GL on the project. Wish i still had mine.
Btw, if you want to do the same like what i did, you will need to drill holes to let the gas out. wear some goggles as it will squirt out dry substance everywhere. After doing that, push it in and position it to how far u want it then tack weld (tube shock absorber) in place. Once u get it squared away, weld all the way around.
PostPosted: Wed Apr 25, 2012 12:54 am
dammmn thats some crazy shit lol. ill keep my mind open on that but thanks for the tip on bullit, sounds filipino
PostPosted: Tue May 01, 2012 5:57 pm
4x 12mm nuts, 2 each side above the rear shackles. thats all my bumpers have ever had to hold them on. they look nice without the rear bar.
PostPosted: Fri Jul 26, 2013 3:20 pm
bringing back this topic. say i don't have a tack welder, could i ghettofy it by using jb weld to plug up the drilled hole?
PostPosted: Fri Jul 26, 2013 11:49 pm
If I remember this right I think you can just drill a hole on other sleeve on both sides and put a nut and bolt. That will hold the bumper in place if u don't have a welder.
PostPosted: Sat Jul 27, 2013 1:31 pm
ohhhh ok that sounds a bit easier. ill will try it out for sure. thanks man
PostPosted: Sat Jul 27, 2013 2:15 pm
think im failing with it. drilled into the bigger piston that fits in the chassis and nothing came out or movement, then theres the smaller and thicker piston which is taking too long to drill into
PostPosted: Tue Jul 30, 2013 8:28 pm
took me sometime too to drill it but once u get pass the gas chamber u will know as there will be some powder stuff that will squirt from it. Just keep on drilling.
Have you at least taken the bumper out from chassis?
a pic would be good.
PostPosted: Fri Aug 02, 2013 8:10 pm
i would also like to see how this is done as i have a 77 Corona wagon and was thinking of how it looks without rear bumper, or with it tucked a little. especially without the US bump stop garbage
PostPosted: Wed Aug 07, 2013 5:48 pm
on my 79 it just un bolted and came right off...
Users browsing this forum: Google [Bot], Yahoo [Bot] and 2 guests
