It is currently Fri May 24, 2013 4:41 pm
Post a new topicPost a reply Page 2 of 2   [ 22 posts ]
Go to page Previous  1, 2
 Post subject: Re: 72 Toyota Corona MKII Station Wagon RT79
PostPosted: Mon Apr 23, 2012 8:44 pm
oldjunker wrote:
nice wagon, i have the same car that's under construction. I'm runnung an 18rg with a 5-speed. I need a rear hatch glass molding as well, as mine is rotted out pretty badly.
I spend about $250. on after market special order stuff that did not work and could not return. Don't make the same mistake. Took mine to Auto glass shop and they pretty much glued the rear and side glass. They had to paint about an inch all around the glass for the adhesive to take (silicone). For the rear, to dress up the work they used a Jeep molding.
Check out rear spares out of Australia (http://www.rarespares.net.au) for all your other weather stripping.
Where did you get the 18rg?
v/r
Israel
PostPosted: Tue Apr 24, 2012 7:54 am
Soooo you just took it to an auto glass shop? Or bought seals from rarespares and let them install them? I need pretty much every damn seal available for mine. And on rarespares it says they have a front windscreen seal for 72-77 but not a 70 like mine. This is weird because they look to be exactly the same aside from the hood and grill... Any insight?
-'70 corona MKII wagon
-'80 rx7 racecar
^Heres my build thread^
Packergreg wrote:
Hezath wrote:
Wagons pull the bitches
