It is currently Fri Mar 27, 2015 9:12 pm
Post a new topicPost a reply Page 2 of 2   [ 35 posts ]
 Post subject: Re: 1978 Toyota Corona from AZ
PostPosted: Wed Feb 06, 2013 5:15 pm
fixed the ball joint and cleaned it up a bit, ordered a few more parts and need to install new seatbelts and wire up my efan.
PostPosted: Wed May 15, 2013 2:33 pm
forgot to update on here, been sorta updating on Stanceworks.
Got another job and a credit card plus the addition of my tax return and its on the road again.
Wired up my efans and got a temp permit to drive around. needs a bit of tuning with the carb but overall I love it.
Today I just got my new windshield, there was a good amount of rust underneath it but with the help of a wire wheel and Rustoleum Rust Reformer, the windshield went on nicely, just need to wait a whole day to even plan on getting it to an inspection station.
As for emissions...idk yet, gonna need some luck with that.
But once all that is out of the picture comes the real progress
Plans are gonna be camaro shocks in the rear due to heavy bouncing and the 4x4 toyota 4 piston calipers $32each at pep boys.
PostPosted: Sat May 18, 2013 8:06 pm
Just started following you on Instagram. Small world. Wide web.
kolxoz
PostPosted: Sun May 19, 2013 2:19 am
"i wanna know how to flush out the cooling ports in the engine just incase without pulling it out, any suggestions?"
When I pulled out the motor in my car(after accident), I found out one of the freeze plugs was leaking and when i took out the rusted plug, sludge had built up near and around the plug and had to pick the sludge out. I suggest if you can replace those and clean it out.
I bet you those passages are block all thru the years like mine. Dont need to take the engine out just the exhaust and the intake manifold for easy access to the side plugs. the leak on mine was at the back where bellhousing so i really couldn't really see it.
PostPosted: Mon May 20, 2013 10:16 pm
ah thanks for the tip. i think mines are alright for now, not overheating or leaking besides the waterpump seepage.
PostPosted: Mon May 27, 2013 11:06 pm
another TEQ in AZ! I'm up in North Phoenix. It looks good, I really like the chalk (?) on the side.
Hit me up if you're ever in town, I'd be down to meet up!
-Nick
TE51 SR5
A187 GSR-VR
JDL Auto Design
PostPosted: Tue May 28, 2013 5:11 am
Looks like a lucky finding, man! In case you would need a cargo shipping for your car there is a helpful link.
cargo shipping
PostPosted: Fri Jun 21, 2013 1:01 am
hey man. I saw your thread awhile back and noticed your Corona getting up and running. Just moved to Avondale and I saw you pull into walmart from across the parking lot off Dysart tonight. I was hoping to talk to you but i just missed you. I have a 1977 Corona wagon with a 20R. however its staying in California. Maybe we could meet up and I could see your Corona. it would help me if i could just see under the hood. All my emissions devices are disconnected. No air pump, no vacuum distributor (the one on the passenger fender well), crappy aftermarket inline fuel pump. i thought the car looked familiar because i saw the chalk on the driver side rear quarter.
PostPosted: Tue Jun 25, 2013 1:04 am
lol its not chalk, i stenciled out those words and sanded em. rusty BUKKAKE lol. and I think you might've meant the walmart on estrella parkway? that's where I work, my car can't drive very far yet, found out I clogged my radiator again so no far meets for me yet.
And for my update, got a weber 32/36 carb and installed. Just need to get a set of cooling port and EGR blockoff plates to clean up more.
PostPosted: Thu Jun 27, 2013 12:18 pm
just randomly thinking, after noticing that my brake rotor had the wheel studs in them, could I convert my corona to 5 lug using a trucks rotor or hub? so many centerlines I would like to rock but they're all 5 lug
PostPosted: Fri Jun 28, 2013 12:44 am
For sale in perth at the moment... love the look of these slammed.
Rhys
Perth, Western Australia
1973 RT81 Corona Sedan
PostPosted: Fri Jun 28, 2013 9:01 am
good god thats the most beautifully clean rt105 so far
PostPosted: Thu Jul 25, 2013 9:32 am
went 4" in the rear and shaved my bumpstops, still not good enough
no im not running s13 se wheels in the front permanently. just wanted to try 65 walls in the rear
PostPosted: Thu Jul 25, 2013 12:16 pm
cut the differential bumpstop
PostPosted: Thu Nov 14, 2013 8:04 pm
a while ago I got a pair of rota rbs from a friend and lowered the rear more by removing leafs and cutting bump stops. last week, I got boso pipes welded up, loving it too much
