It is currently Fri May 24, 2013 3:08 pm
Post a new topicPost a reply Page 2 of 2   [ 25 posts ]
 Post subject: Re: 1978 Toyota Corona from AZ
PostPosted: Wed Feb 06, 2013 5:15 pm
fixed the ball joint and cleaned it up a bit, ordered a few more parts and need to install new seatbelts and wire up my efan.
PostPosted: Wed May 15, 2013 2:33 pm
forgot to update on here, been sorta updating on Stanceworks.
Got another job and a credit card plus the addition of my tax return and its on the road again.
Wired up my efans and got a temp permit to drive around. needs a bit of tuning with the carb but overall I love it.
Today I just got my new windshield, there was a good amount of rust underneath it but with the help of a wire wheel and Rustoleum Rust Reformer, the windshield went on nicely, just need to wait a whole day to even plan on getting it to an inspection station.
As for emissions...idk yet, gonna need some luck with that.
But once all that is out of the picture comes the real progress
Plans are gonna be camaro shocks in the rear due to heavy bouncing and the 4x4 toyota 4 piston calipers $32each at pep boys.
PostPosted: Sat May 18, 2013 8:06 pm
Just started following you on Instagram. Small world. Wide web.
PostPosted: Sun May 19, 2013 2:19 am
"i wanna know how to flush out the cooling ports in the engine just incase without pulling it out, any suggestions?"
When I pulled out the motor in my car(after accident), I found out one of the freeze plugs was leaking and when i took out the rusted plug, sludge had built up near and around the plug and had to pick the sludge out. I suggest if you can replace those and clean it out.
I bet you those passages are block all thru the years like mine. Dont need to take the engine out just the exhaust and the intake manifold for easy access to the side plugs. the leak on mine was at the back where bellhousing so i really couldn't really see it.
PostPosted: Mon May 20, 2013 10:16 pm
ah thanks for the tip. i think mines are alright for now, not overheating or leaking besides the waterpump seepage.
