It is currently Thu Jun 20, 2013 3:57 am
 Post subject: W50 or W58??
PostPosted: Wed Dec 21, 2011 6:13 pm
Which trans best for NA non turbo 7mg?
w50 or w58,theres one of each at the JY?
 Post subject: Re: W50 or W58??
PostPosted: Wed Dec 21, 2011 7:41 pm
Hi Whit, i never seen a bellhousing for a M engine and a W50 but is not impossible to adapt, you know,
if the adapter not a problem for you i will choose the w50, but again the w58 for a N/A 7M is ok for whatever you want, and easier to install of the 2!
PostPosted: Wed Dec 21, 2011 11:26 pm
I'd go with the W58. Easier to find if you blow it up, and parts are readily available. The W50 is out of a MA47 Celica Supra, right?
- 1984 Toyota Celica Supra 5M/5 Speed swapped <3
- 1986 Toyota Cressida 5M/Auto
- 1987 Toyota 4Runner SR5 Turbo <3
- 1985 Toyota Celica GTS Convertible
PostPosted: Thu Dec 22, 2011 7:11 pm
OK so Im thinking the W58,the W50 is in a 81 supra I want the rear from.
Will post pics. :tu:
PostPosted: Fri Dec 23, 2011 9:13 am
:lol: http://www.kodakgallery.com/gallery/sha ... arer-_-Top 8)
PostPosted: Fri Dec 23, 2011 9:39 am
If the W50 is in a supra, then it will have an M series bellhousing and should mount straight up to the 7M. I would use the W58 though, if it is good enough for Toyota to put behind it, then why change it. Depending what car the W58 is coming out of and what it is going into, you may need a different shifter tower.
1985 MX72 soon to be...
1991 MX83 soon to be 7MGTE
PostPosted: Fri Dec 23, 2011 3:42 pm
:tu: OK,W58 is in 84 celica gts and want to put it in 73 mx23 rona mk2 with 7mg.
So this all sounds good,just have to get back to JY before it snows.Its a 4 hour drive.
pic link:: :tu: http://www.kodakgallery.com/gallery/sha ... arer-_-Top
PostPosted: Fri Dec 23, 2011 4:13 pm
That poor GTS. =( And I was just thinking to myself the other night how bad I want a black GTS coupe to park next to my Supra. =(
PostPosted: Sat Dec 24, 2011 7:47 am
isnt the only difference in the input shaft and location of where the slushbox/shifter is? correct me if i'm wrong i've never had a w50 only had one w55 and several w58's
-Ryan-
1987 k5 rock crawler
PostPosted: Sat Dec 24, 2011 1:03 pm
If the W50 came out of a Mk I, it will be a direct bolt-in, but grab the bell housing too! The differences are gearing and only about 10 lbs of weight - the W50 is an all iron case, the W58 is aluminum.
W50
First Gear: 3.287:1
Second Gear: 2.043:1
Third Gear: 1.394:1
Fourth Gear: 1.00:1
Fifth Gear: 0.853:1
Reverse: -4.039:1
W58
First Gear: 3.285:1
Second Gear: 1.894:1
Third Gear: 1.275:1
Fourth Gear: 1.00:1
Fifth Gear: 0.783:1
Reverse: -3.768:1
DD - '81 Corona wagon - 22R hybrid P&P, Comp 280, Si valves, Erson springs/retainers, Weber, Cannon, MSD, Thorley, Borla, 3rd gen/Mk II front suspension, Cressida Big Brakes, coilovers, AGXs, Addco, all urethane bushings, Hilux leafs
PostPosted: Sat Dec 24, 2011 2:39 pm
OK geat info I will try to pull the W58 next week. :tu:
Theres a 5m 85? Cressida there also,maybe I will get the front brakes from it? :idea:
PostPosted: Sat Dec 24, 2011 6:39 pm
Theres a Cressida in the pics. link I posted above.
Whats that got for brakes or other goodies?its an auto.
PostPosted: Sun Dec 25, 2011 1:05 am
It'd be IRS and rear disc brakes being an 85.
-Ryan-
