It is currently Tue May 05, 2015 11:28 pm
Post a new topicPost a reply Page 1 of 1   [ 17 posts ]
 Post subject: LSD code for 81 supra ma47?
PostPosted: Wed Dec 21, 2011 6:17 pm
this is what i copied from firewall tag.
888-HB85-F302-W50
is F302 lsd equipped?
 Post subject: Re: LSD code for 81 supra ma47?
PostPosted: Thu Dec 22, 2011 9:59 am
LSD celicasupra rear should have the last number odd like a F283 and so on ive got an 79rear on mine F312 which translate to 3.9 gear ratio non LSD but good find though they are getting pricey these days 500bucks or so for a complete rear end
1981 Toyota Celica GT 550,000 miles on original engine and tranny,79 Supra F312 rear
1996 Lexus LS 400 290,000 miles going strong
2002 Toyota Sequoia 4WD 147,000 too young
PostPosted: Thu Dec 22, 2011 2:49 pm
81 supra LSD is rare.
PostPosted: Fri Dec 23, 2011 1:42 am
From what I've heard you can also use an LSD from a 84-85 Celica GTS too
PostPosted: Fri Dec 23, 2011 8:37 am
Well thats great info Oracles as the W58 trans is in a 84 GTS at the same JY and its already up in the air.
JY's in New York are not pick-N-pull type yards.Cars have been there for many years in no special order.
So can I assume the GTS is stock with the LSD?
PostPosted: Fri Dec 23, 2011 9:09 am
:tu: CLICK THE LINK BELOW FOR JY PICS. :tu:
:lol: http://www.kodakgallery.com/gallery/sha ... arer-_-Top
PostPosted: Sat Dec 24, 2011 7:52 am
only if you have the 7.5" f code carrier. if you have a 6.7" t code it wont fit :wink: also the 84 wasn't lsd equipped only the 85 was. if anybody is looking for a 7.5" f code non lsd rear there is a complete 80 supra nearby me that runs and drives for 500 bucks. my finders fee is the trans and pedal assembly though and you can have the rest of the car :tu:
-Ryan-
1980 mx32 riding on advan a3a's and hachi suspension
1987 k5 rock crawler
PostPosted: Sat Dec 24, 2011 12:20 pm
ONLY the '85 Celica GT-S (IRS) with a manual trans came with a 7.5" (F-code) diff - F312. I've never heard of one with LSD in the US - maybe from Canada. Your best bet for an LSD carrier is out of a Mk II Supra or a truck.
All other RWD Celicas - '71-'85 - (NOT Supras) came with 6.7" (T-code) diffs, and none of those had LSD.
All Mk I and Mk II Supras came with F-code diffs, but only Mk I's from Canada had LSD. Many Mk II's had LSD.
Mk I's are SRA, Mk II's are IRS. All have 4-wheel disc.
DD - '81 Corona wagon - 22R hybrid P&P, Comp 280, Si valves, Erson springs/retainers, Weber, Cannon, MSD, Thorley, Borla, 3rd gen/Mk II front suspension, Cressida Big Brakes, coilovers, AGXs, Addco, all urethane bushings, Hilux leafs
PostPosted: Sat Dec 24, 2011 6:34 pm
Well YOUR diff isn't LSD because it's still sitting on the ground somewhere! lol snicker snicker
PostPosted: Sat Dec 24, 2011 8:31 pm
LOL - but no matter where it sits, both axles DO turn the same direction!
PostPosted: Sun Dec 25, 2011 1:02 am
Btw p types were only lsd. L types werent iirc
-Ryan-
PostPosted: Thu Feb 16, 2012 5:52 pm
F is your ring diameter
30 is your gear ratio
2 is LSD or open
in your case 2 is NO LSD
Usually a good rule of thumb is odd number (3, 5) is LSD
PostPosted: Thu Feb 16, 2012 6:29 pm
-1982 Toyota Celica Supra-
-Searching for a E30 Corolla-
PostPosted: Thu Feb 16, 2012 6:48 pm
Thanks for posting the chart,I will print it out.
I just got my rear axle from the 80 supra.
There is a 84 supra I will get the trans. and rear gear from.
PostPosted: Thu Sep 19, 2013 2:46 pm
"All other RWD Celicas - '71-'85 - (NOT Supras) came with 6.7" (T-code) diffs, and none of those had LSD."
The '78-'81 Celica 2000 GT outside the US came with LSD. It's shown in the Haynes repair manual, in the parts list and also in the sales brochure. I have a sales brochure that I can scan and post.
PostPosted: Fri Nov 08, 2013 9:02 pm
So if I understand correctly the F283 is a 4:30 LSD rearend.
PostPosted: Fri Nov 08, 2013 9:40 pm
This is the tag from the car. Image
