It is currently Sat May 25, 2013 10:32 am
Post a new topicPost a reply Page 5 of 6   [ 119 posts ]
 Post subject: Re: RA64
PostPosted: Tue Mar 27, 2012 10:18 am
Another engine change in this machine, from 4TGTE to a 3TC-Turbo :mrgreen:
Due to a unsuspected customer, that really really want the 4T, i was obligated to let someone else deal with the 4T and i decide to install a totally built 3TC instead, still going to have the power but not the wow factor, hell, i can live with that!
PostPosted: Tue Mar 27, 2012 10:33 am
The 3TC is still a solid choice. Is it going to be EFI'ed?
PostPosted: Tue Mar 27, 2012 10:39 am
With all the parts i was going to buid the 4T i am building a stout 3TC with only the adition of stainless Valves bronze valve guides and new dual valve springs, this will have the same HP i was going to get out of the AWESOME 4TGTE.
Head with Stainless valves 1mm oversize intake and exhaust.
JE 87mm Turbo Forged Pistons
PostPosted: Mon Apr 09, 2012 2:51 pm
PostPosted: Thu Apr 12, 2012 8:32 am
Much better rim choice, even if they are a bit honda-ish :wink:
PostPosted: Thu Apr 19, 2012 1:03 pm
Man like what your doing to the car. I just bought a 85 GT-S coupe that I'm Re-doing from the ground up. Well hope to see more of your build
PostPosted: Fri Apr 20, 2012 12:59 pm
Cut the big intercooler to size so it will fit right, as i dont want to get rid of the A/C system!
PostPosted: Wed May 02, 2012 2:42 pm
Engine swap started RA64 to TA64, i cut the RA brackets from the X-member and clean em up and install the RA motor mounts to the 3T engine Brackets, and then bolt the cuted X-member brackets to the motor mounts, install the W58 trany/3t bellhousing combo on the factory trany mount,this is the easiest Swap i have ever done, just need to weld the 1/8' 4"x5" plate to the X-member and then the brackets to the plate, CHECK IT OUT !
Cleaned X-member
Engine mocked up,
Trany centered.
Driver side mount,
Passenger side mount
Engine sitting in its mounts not welded yet.
PostPosted: Thu May 03, 2012 9:23 am
Engine swap finished welded up and painted!
PostPosted: Thu May 03, 2012 9:57 am
Looking good!! Cant wait to see the finished engine in this.
PostPosted: Thu May 03, 2012 12:30 pm
PostPosted: Sat May 05, 2012 3:56 pm
Still not desided yet, the day i get ready for the machine shop i will tell,
PostPosted: Mon May 07, 2012 9:58 am
?!?!?! Thought someone bought it off you?
PostPosted: Mon May 07, 2012 11:21 am
Dead beat buyer from cali but is better i keep it, anyway i really didnt want to sell it anyways.
PostPosted: Mon May 07, 2012 8:50 pm
Here is the intake i scored for my 3TC tomorrow clean it up sand it down and black wrinkle finish paint will be applied if it doesn't rain!
PostPosted: Thu May 24, 2012 7:28 am
More updates coming soon stay tuned.
PostPosted: Sun Jun 03, 2012 8:03 pm
Just mocking up some stuff to make sure everything will fit when is time to install all for the last time!
PostPosted: Tue Jun 05, 2012 9:45 am
Looks like you have more then enough room under the hood. Shoulld be quick!
PostPosted: Tue Jun 05, 2012 3:53 pm
UtahSleeper wrote:
Looks like you have more then enough room under the hood. Should be quick!
I hope when all is installed it will be easy to work on it, remember this will have A/C and all the amenities.
PostPosted: Wed Jun 06, 2012 4:22 pm
Turbo manifold fabrication underway not finished yet but it is looking awesome biggrin :mrgreen:
Users browsing this forum: Toyohead and 5 guests
