It is currently Sat May 25, 2013 8:02 pm
 Post subject: First Manual Swap | MX73
PostPosted: Thu Nov 10, 2011 7:18 pm
Been a while since I've posted but would like to share photos/progress with our first manual swap.
I am currently working with my fiance on his mx73 manual swap. We are actually looking for a 5mge flywheel at the moment. Worse case scenario, buying it on eBay. I've called many auto wrecking companies but they have non available. Craigslist, none. Junk yards, none. Hoping that posting on forums will help. My goal is to be active on the forums so I can provide progress and updates.
A friend of mine provided me a 7mgte flywheel and he told me that he's done x7 manual swaps with it many times so I made an assumption that it would be possible. I bought a 7mgte clutch kit and all the necessary bolts/nuts. BIG ISSUE was that the throw out bearing sleave/collar for a w58 is too small for the 7mgte clutch. It came with a bearing but it was LARGER! It was meant for a R154 not a w58! We stopped it there, so now we are sticking with Plan B which was suppose to be PLAN A from the get go.
I will post updates/progress.
Thanks for looking!
 Post subject: Re: First Manual Swap | MX73
PostPosted: Fri Nov 11, 2011 3:32 am
try celicasupra.com, should find your flywheel there.
PostPosted: Fri Nov 11, 2011 1:49 pm
7m and 5m flywheels for w series trans are the same. you also may try celica-gts.com out of the 3k members 75% of them are from the PNW and i would bet one of them has one
-Ryan-
1987 k5 rock crawler
PostPosted: Fri Nov 11, 2011 4:13 pm
Yup, 5 and 7M flywheels are interchangeable. You should be good to go, unless you got a 7MGTE flywheel as the R154 flywheel is different. Look for a 7MGE flywheel instead, should be very easy to find in the junkyards. Heck, you can probably buy an entire 5 speed MkIII supra for the price of a new flywheel. :lol: Good luck with the swap. A 5 speed really livens those cars up!!!
1985 MX72 soon to be...
1991 MX83 soon to be 7MGTE
PostPosted: Fri Nov 11, 2011 7:36 pm
OkieRA29, buzzbomer, terolla, thank you guys for the information along with the forum sites. I will be meeting with a guy from jzxproject on Sunday for the 7mge flywheel. He's selling it for $50. Not bad. I've posted photos/updates below.[/color]
UPDATES/PROGRESS WITH PHOTOS
Aftermarket pos alarm wires taken out, clutch put in. Now I am waiting on the 7mge flywheel which I will receive on Sunday then the swap continues...
PostPosted: Sun Nov 13, 2011 2:21 am
Which driveshaft are you using? The front half of a MKIII Supra W58 Driveshaft is ideal for a Cressida 5 speed conversion. Just curious, if you guys have the correct one.
Good luck!
- 1984 Toyota Celica Supra 5M/5 Speed swapped <3
- 1986 Toyota Cressida 5M/Auto
- 1987 Toyota 4Runner SR5 Turbo <3
- 1985 Toyota Celica GTS Convertible
PostPosted: Sat Nov 19, 2011 5:05 pm
I got a question, what kind of clutch and brake pedals do you use on this type of swap? Would it be an MKII or MKIII Supra? Will it need any modifications?
1980 Toyota Corolla 2DR Sedan - 3TC Street Modded
1980 Datsun B310 Coupe - Low + Slow
2006 Scion xB - DD
PostPosted: Sat Nov 19, 2011 8:35 pm
list of ingredients needed for a 5 speed swapped MX73
MkIII Supra W58 and front half of driveshaft.
MkII Supra clutch pedal and brake pedal
MkII Supra Clutch master cylinder.
You can also use AE85/6/8 pedals from what I have heard.
The MkII clutch pedals will need some 'adjustment' where the top bolts into the car. It is hard for me to explain, but when you hold the clutch pedal in the dash, you will see what I mean. Supposedly, the AE8x pedals require no adjustment and are just a drop in fit. You can buy a 5M flywheel, but just grab the flywheel off the MkIII Supra you get the W58 from.
PostPosted: Sat Nov 19, 2011 10:56 pm
Saw this on jzxp. I used hachi roku pedals and sliced off the piece of brake pedal on the left side. Also i heated and bent the hachi clutch pedal forward a hare.
PostPosted: Sun Nov 20, 2011 1:21 am
You will need some kind of bracket to re enforce the clutch pedal just like said above^^
PostPosted: Thu Feb 02, 2012 1:14 pm
Been a while and the swap was a SUCCESS! Thank you everyone for providing helpful information! If you would like to see photos of the swap, please see below. Thanks again!
http://www.facebook.com/media/set/?set= ... 47a48dc423
PostPosted: Thu Feb 02, 2012 2:24 pm
That's good news. Keep us updated with any other mods and pics of course. I'll be sure to show your post to my girl and hopefully she can be somewhat inspired to help me with my cars, although I highly doubt it, lol. Good luck.
2006 Scion xB - DD
PostPosted: Sun Feb 12, 2012 8:39 pm
nice any other plans? turbo?
Users browsing this forum: smootharchi and 4 guests
