It is currently Sun May 19, 2013 8:11 am
 Post subject: Need help in Houston for 79 MX32
PostPosted: Sun Jan 13, 2013 1:44 am
Hi all,
I have 79 MX32 with carbie, it has only 55K miles on it. It was running fine then i didnt drove it for few months. It still starts but doesnt want to stay on. Is there anyone in Houston familiar with 4M engine that can help me out. If you know anyone please let me know. My friend drove my car to his shop but he is too busy to look at it and I really want this car to be up and running.
Thanks you all.
 Post subject: Re: Need help in Houston for 79 MX32
PostPosted: Sun Jan 13, 2013 8:03 am
I have a good freind in Houston who is a master when it comes to toyota and carbs give him a call his name is carlos.
ill shoot you his number through PM
Shakotan_culture@instagram
PostPosted: Sun Jan 13, 2013 2:29 pm
Thanks. I send you PM.
PostPosted: Mon Jan 14, 2013 1:40 pm
mine idles high all the time, don't drive it enough to work on it. mine had some wiring gremlins, the fuses under the dash were kind of messed up bc of their brackets being old and brittle and not always connecting. if it moved at all, even just hitting a bump or coming to a fast stop, the car would die because of that. there's so little wiring in the carbed car to worry about that if the carb is ruled out it should be easy to trace.
PostPosted: Mon Jan 14, 2013 1:41 pm
btw, when i swap engines you're welcome to drive up here and pick up this 4m/auto. i'll let you have it cheap.
PostPosted: Thu Jan 31, 2013 4:28 pm
Still no luck yet. I wish someone can help me to have a look at it. Its so hard to find someone down here who knows about cressida.
PostPosted: Fri Feb 01, 2013 10:01 am
dont need a cressida specialist. carbed cars are simple, any decent mechanic should be able to help you out.
PostPosted: Sat Feb 02, 2013 7:53 am
Spoke to a shop, i will take it over there, lets see what happens?
