It is currently Sun Jul 05, 2015 6:37 am
Post a new topicPost a reply Page 5 of 5   [ 97 posts ]
Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: 1972 Toyota Carina TA12
PostPosted: Wed Jul 02, 2014 6:43 pm
Your craftsmanship is stunning! Absolutely terrific, thanks for sharing
kolxoz
PostPosted: Thu Jul 03, 2014 1:50 am
Thanks :roll:
http://i.imgur.com/eKvzJNd.jpg
http://i.imgur.com/4ezXM1p.jpg
Today left side to be done. Takes few hours !
PostPosted: Thu Jul 03, 2014 1:59 pm
The graphics REALLY set off the car! Looks so good!
kolxoz
PostPosted: Tue Jul 08, 2014 1:53 pm
nice jellybeans
PostPosted: Thu Jul 10, 2014 12:12 pm
Thanks! If you refer to the mag rims Errolae? They are 75 wolfrace slotmags.
PostPosted: Thu Jul 31, 2014 2:54 am
Looks great! :)
PostPosted: Sun Oct 12, 2014 9:34 am
At the moment busy to build a fresh 2TG powersource to convert the heart also into a GT version.
Have an 222 head with biggest stock valves/lift/duration from a friend, flowed and ported it. And for short block a 2T donor with exceptional low mileage for its age, with dismantling see nice fabric hone streaks in cils, bearings (with the wide obsolete shells) has nice tight tolerances and so on. Even deck has only fly-rust instead of the usual deep pits. :shock: This block has been stocked in a shed for maybe 30+ years after the 73 carina crashed.
Some brick building to see how its going to look:
http://i.imgur.com/KfA7BqV.jpg
Want oil squirters for extra piston cooling:
http://i.imgur.com/wjw93Qq.jpg
Polished the rods and balanced, but want to remove some more from bigends:
http://i.imgur.com/GESH3y8.jpg
If i had funds and a findable 3T crank made a stroker but for now this one will do:
http://i.imgur.com/TE5DiSL.jpg
Oil squirters, diy. Want them to open @ around 2 bar. Orifice 0.8mm (4AGE has 1.4mm)
http://i.imgur.com/8FahXYk.jpg
bokeh picture of cap/cover
http://i.imgur.com/4VnE644.jpg
 Post subject: Re: 1972 Toyota Carina TA12, lets build a 2TG for it.
PostPosted: Sat Oct 18, 2014 7:08 am
love the amount of work and dedication you put into this
1986 Camry SV11 Gli
1975 Datsun Cherry E10
1969 Crown MS55 - sold
1998 Starlet EP91
1979 Corolla KE50
2002 Kawasaki ER5
PostPosted: Sat Oct 18, 2014 1:24 pm
on your adapter, are those special stud ends or just machined allen-head bolts?
-Matt
PostPosted: Mon Oct 20, 2014 2:03 pm
They are shortened allen bolts indeed on first prototype, this one went to norway, it has flat surfaced sunks in plate.
Lateron i chose 90 degrees countersunk holes with bolts. Works too.
PostPosted: Mon Mar 02, 2015 5:22 pm
Turned out great! Very impressive restoration skills! :tu:
PostPosted: Tue Mar 03, 2015 1:50 pm
Thanks. Drive it for a year now, and like it a lot. 2TB is not the best revvy engine so 2TG should go in this year. It will be balanced and have some work done on it, like custom chain tensioners with rollers, oil squirters and a increased volume oil pump.
PostPosted: Thu Mar 12, 2015 2:48 pm
great work on the carina :tu: :tu: :tu:
wish i had that same amount of interest and skils.beutiful car
PostPosted: Sat Mar 28, 2015 12:04 pm
Thanks ! Lend a engine stay, coated pistons, made custom 2nd chain for 2TG, assembling starts soon now
PostPosted: Wed Apr 29, 2015 1:44 pm
Getting along with the 2TG block. Pistons and crank in etc, need to do some more. 222 head with big valves/cam duration/lift and 9.8 CR pistons
PostPosted: Wed Apr 29, 2015 6:49 pm
That is a cool Oil Pan.
The Librarian has Spoken...
PostPosted: Wed Apr 29, 2015 10:01 pm
Oil sqirters are in and need cooler oil so made custom cooling oil pan
Users browsing this forum: Yahoo [Bot] and 7 guests
