It is currently Tue May 21, 2013 2:28 pm
 Post subject: Got my rims today!
PostPosted: Sat Mar 09, 2013 4:00 pm
Hi,
got my rims today, tires still missing, wanted to go 195/50-15 or would you suggest 195/55-15 ?
it is 8x15 ET15 front and ET0 out back, cannot go any wider as it seems already quite tight.
TK
 Post subject: Re: Got my rims today!
PostPosted: Sat Mar 09, 2013 7:54 pm
How low are you planning to drop it? I'd go with the 55's if you aren't dropping too far, and 50's if you want to go a bit lower. Both are the same width, just different diameter/profiles.
PostPosted: Sun Mar 10, 2013 10:44 am
After visiting the tire shop today I decided for the 55 tires, look more oldschool to me and i need to drive the car on non-perfect roads should be the better option to fill the wheelhousing without going to the ground. Will post pictures once they are mounted.
Regards, TK
 Post subject: Re: Got my rims today! - updated pic
PostPosted: Sun Mar 10, 2013 4:28 pm
Hi,
OK, now rims and wheels are mounted on original suspension, look a bit strange ---> next step - suspension !
TK
PostPosted: Sun Mar 10, 2013 7:36 pm
Can't wait to see it. :tu: :mrgreen:
PostPosted: Mon Mar 11, 2013 9:43 am
Great Looking Car!! Keep the pics coming.
PostPosted: Tue Mar 12, 2013 9:44 am
waiting for the pics :tu: :oops: :P :D
PostPosted: Tue Mar 12, 2013 9:49 am
damn looks good. My 15x9 et 0 wheels rub the inside well on my corona when its completely turned. I'm getting 1 inch spacers and already have the fender flairs to install.
PostPosted: Tue Mar 12, 2013 11:30 am
Doesn't look too bad at all, actually. I mean, a bit high compared to some of the cars on here but not nearly as 4x4ish as some of them turn out. Nice choice for the rims and colour, great combination!
PostPosted: Thu Mar 14, 2013 11:45 pm
very nice, need to low down your suspention. I used to have one, ut I go with 13/7 RIMs :D
PostPosted: Fri Mar 15, 2013 7:55 am
Looks good. 8) :tu:
 Post subject: Got my rims today! -- now lower
PostPosted: Wed Mar 20, 2013 3:41 pm
Hi,
just got my car lowered and the fender walls bend yesterday. The car is starting to make more fun each day :-) Could go way lower but the streets overhere don't allow it.
Next up some small spacers out back and and exhaust .... the current one is pieced together from 20 pieces, will take a picture once it is our -- looks like art !
TK
PostPosted: Wed Mar 20, 2013 9:51 pm
how did you lower the car. and how is your front suspension setup. Is it a coild over a shock, or the older style that looks like 66-69 ford mustang type suspension.
PostPosted: Wed Mar 20, 2013 11:10 pm
Love the copper color, the car is cherry!
PostPosted: Thu Mar 21, 2013 5:03 am
Wow! bro very nice toy!
PostPosted: Thu Mar 21, 2013 5:26 am
Hi,
it is like old Chevy style, meaning 2 A-arms with a spring between the lower A-arm and the chassi and a shock running in the middle. all very low, not using a tall tower for the spring.
Tomi
PostPosted: Sat Mar 23, 2013 1:07 pm
Hi,
today I installed some 8 mm spacers on the back axle, fits perfect. Even though my suspension is still quite soft, no touching with at least 5-8 cm of suspension. As I have 15x8 ET 0 plus 8mm of spacer, i guess with a stiff suspension ET-15 should go .... bad luck for me, maybe next time am brave enough to go right away with less ET or with an inch more of wheel width.
