It is currently Wed May 27, 2015 9:23 pm
Post a new topicPost a reply Page 10 of 10   [ 194 posts ]
Go to page Previous  1 ... 6, 7, 8, 9, 10
 Post subject: Re: 1970 Corona Wagon MKII(Megasquirt 22RE)
PostPosted: Sat Jun 14, 2014 1:30 pm
Correct, Citroen CX.
Car is looking great man! Good to drive? Doing well on long trips?
kolxoz
PostPosted: Mon Jun 16, 2014 8:37 am
Doing awesome on long trips. The only changes I need to make are with the exhaust. Im going to extend the tip past the rear bumper, add a flex joint after the down tube and jam nut the collector bolts. Two of them keep coming loose and rattling. Oddly enough there is never any exhaust leak when it happens because of the socket type connector.
Oh and the bench seat. Damn that thing is uncomfortable lol. Ill be switching back to OG buckets soon.
^Heres my build thread^
Packergreg wrote:
Hezath wrote:
Wagons pull the bitches
PostPosted: Mon Jun 16, 2014 2:13 pm
Just Reading your thread - the hole thread. Fantastic wagon and realløn cool looking - including all the great unseen stuff - engine etc. keep it coming ...
PostPosted: Mon Aug 11, 2014 10:00 am
No really good pics yet because Im a lazy FARK but more will happen when its not raining. But fender mirrors ftw.
LOL @FARK as an autocorrect. At least you keep the essence of my profanity :P
PostPosted: Tue Aug 12, 2014 4:37 pm
What brand white walls are those? Do you like them?
I'm thinking of rocking the white walls myself
kolxoz
PostPosted: Tue Aug 12, 2014 7:05 pm
They are atlas brand whitewalls. I like them pretty good. Just make sure you prep the inner surface of the wheel before installing them. I roughed the inside edge up with 40 grit sandpaper and rubbed it off with lacquer thinner. I also wiped the whitewall down with alcohol to get any molding oils off of it and wiped with lacquer thinner on the ribbed surfaces that will be pinched between the wheel and tire. I have had no slippage issues with mine, even getting up to 85 on the highway.
PostPosted: Mon Aug 25, 2014 6:44 am
Finally some decent pictures of the wagon. DANKFEST 2014 in Winston-Salem NC
PostPosted: Sat Sep 27, 2014 7:46 pm
What kind of MPG do you get on your setup? I am thinking of getting one of these for a driver.
PostPosted: Fri Nov 21, 2014 9:21 am
One of these what? Engines or the car. My 22re has a slightly larger lift and duration cam, ported head, header, etc. and it probably gets about 26 or so. Probably could get better but I dont take it easy on the car when I drive it lol.
PostPosted: Fri Nov 21, 2014 11:51 pm
[/img]
Car came a long way up :tu:
and if that shot is not sexy then I don't know what is
 OnlineProfile
PostPosted: Mon Dec 08, 2014 2:41 pm
I appreciate man :mrgreen:
Ive just been driving it while I finish my beetle. But I traded a washer/dryer for this and made it my daily. IT had been sitting for quite a bit of time at a shop for lack of payment of an engine rebuild. Score for me. Replaced pretty much all of the CIS fuel injection system and it purrs. Lift-off oversteer is fun lol
Started like this
a little fungi
and then
to
No interior shots but it cleaned up really well and unlike most vw's all the electrics work(now at least)
PostPosted: Thu Apr 02, 2015 8:17 am
Anyone know where I can get a headlight switch for the wagon?
Update: Im rerouting the fuel pump, tank outlet etc., so it hopefully gets a better feed and quiets down. Also made a double, rubber-isolated bracket for the fuel pump to help as well. There will be 1/2" line feeding the pump now.
Also got a fuel sender from auto zone that happens to be close in ohm range to the original(and old gauge still works). 0-90ohm compared to 17-120ohm.
Ordered a brake booster from rockauto so i can finally have power brakes lol. Hopefully they dont have it misprinted as in stock...
PostPosted: Fri Apr 03, 2015 7:16 am
Are you familiar with Carlyn Dinkler? He sells parts for RT Coronas: cdinkler@bellsouth.net
What symptoms of fuel delivery problems have prompted the change?
Double isolating the pump is a major help with noise. I've got a large pump on my car that I can't even hear once cruising.
kolxoz
PostPosted: Fri Apr 17, 2015 5:58 am
Thanks for the email address.
The change is prompted by the fact that after the tank gets under half full, the pump gets louder because its being fed via siphoning. The fuel outlet is halfway up the tank and has a diptube going to the bottom. While this has worked for a while, I dont like making the pump work so hard and I cant deal with the noise.
