It is currently Tue Apr 28, 2015 3:29 am
Post a new topicPost a reply Page 8 of 10   [ 194 posts ]
Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
 Post subject: Re: RT78 Corona Wagon Build Thread(22re swap and more)
PostPosted: Mon Dec 16, 2013 11:04 am
Decided im not facking with the stock 22re computer and harness because im going to have to cut it to shreds. Megasquirt is a much better option and it will let me tune the car as well as keep the engine bay mega clean which I consider very important. Ive helped my friend tune his turbo volvo 242 on MS1.3 and its pretty straightforward. Also, I didnt powder coat and take all that time making everything look sexy just to ruin it with wires.
http://www.diyautotune.com/catalog/megasquirti-efi-system-smd-pcb357-black-case-p-172.html
Im sure some other people are running megasquirt on JNC but I havent seen it in the yota thread. Any success stories?
1970 corona MKII wagon (22RE swap)
Many other car/truck/bike projects
^Heres my build thread^
Packergreg wrote:
Hezath wrote:
Wagons pull the bitches
PostPosted: Mon Jan 13, 2014 7:20 am
Progress!
Here are a few pics of the wiring. Megasquirt really is the way to go for standalone engine management because of its simplicity. I have MS1 with the v3.57 board and MS harness. A Bosch 4.2LSU O2 sensor with AEM UEGO AFR gauge is being used for tuning. Everything is connected and the car is talking to the computer at this point. So now I have to get the cooling system all set up which shouldnt be hard or time consuming. Im going to use my old rad to start with, then drive it to somewhere and have a custom aluminum one made because ballin'.
PostPosted: Fri Jan 24, 2014 9:12 am
Front end most of the way back on. Wires loomed. Running decent but needs a fair amount of tuning. Couple more days of work to drive it. But now, we snowboard!
much sidepipe. such loud. so sex. wow.
 Post subject: Re: RT78 Corona Wagon Build Thread(Megasquirt 22RE)
PostPosted: Mon Feb 10, 2014 12:23 pm
Its officially on the road now. Had to re-align the front end because of all the new stuff but steers good and straight now. Got off to a slow start with megasquirt but have it running pretty well now. Pulls like hell through all gears!
Rockin' it hoodless for a little while longer. Changed the intake tube a bit to make room for a thicker aluminum rad in the near future.
P.S.
The coolant on the floor is the result of me spilling it onto the catch tray under the rad. :oops:
PostPosted: Wed Feb 12, 2014 6:38 pm
What a cool project!
White walls on steelies are aces. Good choice there.
Great work on that engine and Megasquirt. I started MS but bailed out because electritional things are too complicated for my simple brain.
kolxoz
PostPosted: Mon Feb 17, 2014 7:51 am
Appreciate it. The VAST ignition system was the only thing that wasnt 100% straightforward. Finding the pinouts for some of the sensors took a fair amount of google searching as well but all are available. DIYAUTOTUNE has a pretty good instructional page on what settings to start with on the 22re which made getting it running way more simple.
PostPosted: Fri Mar 21, 2014 6:45 am
Gauge panel to replace the non-working radio in the middle of the dash(really shitty pic). VDO mech. oil pressure gauge and VDO clock on the way to keep my AFR gauge company in the panel. Will be powder coated black to match the rest of the dash. Fits like a glove :tu:
PostPosted: Fri Mar 21, 2014 9:38 pm
Really nice wagon...love everything ya done so far. :tu:
PostPosted: Sat Mar 22, 2014 8:11 am
So cool. Love everything! Nice work
kolxoz
PostPosted: Wed Mar 26, 2014 10:13 am
Gauges. Going to put the black face back on the AFR gauge tonight.
PostPosted: Thu Mar 27, 2014 7:21 am
Header and downtube ceramic coating. This is before polishing so you can see what a PITA shiny ceramic headers are.
 Post subject: Re: RT78 Corona Wagon(Megasquirt 22RE)
PostPosted: Fri Mar 28, 2014 9:18 pm
Sick corona
wondering if you would part with the radio and bezel I'mlet me know interested
PostPosted: Mon Apr 07, 2014 5:40 am
Nah man I think Im going to hold on to all these parts.
Sound and heat shielded most of the the pan
PostPosted: Wed Apr 09, 2014 7:41 pm
Car makes no noise now when things are dropped in it. Still needs a few wrinkles worked out up front as well as some more coverage but its much nicer than it was.
Some padding
Some carpet
PostPosted: Thu Apr 10, 2014 12:51 pm
Great work and your MS install looks like it went in a lot cleaner then mine. Great work.
PostPosted: Fri Apr 11, 2014 5:43 am
Where did you buy the carpet from? Looks nice. Plush style?
kolxoz
PostPosted: Fri Apr 11, 2014 11:12 am
Preesh guys. Got the carpet and padding off of ebay. EZFLEX cut-pile carpet and 40oz, 1/2", jute padding. Wish I would have bought some more because I need to carpet my shitty looking hatch panels. I also have my header polished now so the engine should be buttoned up soon.
PostPosted: Fri Apr 11, 2014 8:59 pm
Great! Thanks for the tip. I was thinking I had to spend $200 for a pre-cut carpet.
kolxoz
PostPosted: Sat Apr 12, 2014 7:17 am
Yea man, I spent less than $100 all said and done
PostPosted: Mon Apr 14, 2014 8:39 pm
Carpeted the garbage looking hatch panels.
A little closer to finishedish
Close up
Users browsing this forum: Google [Bot] and 5 guests
