It is currently Sun Jul 05, 2015 12:49 am
Post a new topicPost a reply Page 6 of 10   [ 194 posts ]
Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9, 10  Next
 Post subject: Re: rt78 corona wagon budget build thread(pics updated 3/2/1
PostPosted: Fri Mar 16, 2012 9:30 pm
Does anyone know if there is a 5 speed that will bolt up behind the 8rc? Even if I have to shorten the driveshaft or swap out the rear end as well, I would like to do a 5 speed swap. Dont some of the early celicas have 5 speeds with an 18rc?
P.S.
I dont know if I ever gave any updates on the amount spent on this car but the total so far is around $1800. Just a little tidbit I thought I would add since this is a budget rat! lol :mrgreen:
^Heres my build thread^
Packergreg wrote:
Hezath wrote:
Wagons pull the bitches
PostPosted: Fri Mar 16, 2012 11:49 pm
any W50 that was behind a 18RC will bolt on but the cross member will need re-work. I am not sure about the driveshaft but I believe that it is different from the 4 speed
NOT STOCK!
PostPosted: Sat Mar 17, 2012 4:48 pm
Solid. I dont mind a little re-work and I can make the driveshaft work if need be. So I guess the search begins for a trans now!
PostPosted: Sat Mar 17, 2012 8:21 pm
Shisety picture but a precursor to some more bawsome attitude about to go on the wagon.
PostPosted: Sat Mar 24, 2012 5:57 pm
Progress has slowed thanks to a broken collar bone via mountain biking. But thanks to my dad helping we powder coated the wheels a darker blue and put on the tighty whiteys(portawalls) today.
 Post subject: Re: RT78 Corona Wagon Budget Build Thread(pics updated 3/24/
PostPosted: Mon Mar 26, 2012 1:26 am
Looks mint!
Wish my car had paint like that. Patina'd silver is so boring
PostPosted: Mon Mar 26, 2012 5:20 pm
Hey dude think you could pm on how you went about cutting the springs on this thing or how many you actually took off on the front?
PostPosted: Thu Apr 19, 2012 10:55 am
http://gearboxmagazine.com/2012/03/toyota-corona-mkii-on-a-budget/
Dennis Dejong prepared this article on his online magazine http://www.gearboxmagazine.com about my wagon. I was very excited to share my car and story with them and very much support these guys and their mission to unite gearheads from around the globe.
 Post subject: Corona Wagon Budget Build Thread(1970)
PostPosted: Thu Apr 19, 2012 11:12 am
Found out a good way to protect the patina on a car with paint like mine is to use mag/aluminum polish. It brought out a nice "sheen" and makes water bead up pretty well. May try and polish it with some other things over the weekend. I figured I would let people that have followed this thread know as many guys prob have very oxidized like I do. More pics when I get time and Im off work hahaha. Deuces!
 Post subject: Re: RT78 Corona Wagon Budget Build Thread(LIKE A BOSS)
PostPosted: Mon May 28, 2012 8:33 pm
Not a yota but added some more JNC to my collection this weekend. Got to tune it up and then start lightening it more. Needs a few things to make it a nice racecar imo.
'80 RX7 racecar
as bought
De-stickerfied
 Post subject: Re: RT78 Corona Wagon Budget Build Thread(Timing advance hel
PostPosted: Fri Jun 22, 2012 5:39 am
Trying to get the timing advance sorted out on this thing. Its a bitch to crank and im 99% sure its because I messed with the advance/retard knob on the backside of the dizzy. Does anyone know the stock setting and/or which direction (CW or CCW) does what? Chilton doesnt seem to say anything about it...
PostPosted: Fri Jun 22, 2012 12:49 pm
The "Vernier"? Thats what my book calls it, there is no real standard spot for it because it will just keep spinning. The book says its for very VERY small adjustments of timing once you have found the correct timing, its supposed to get rid of pinging. I don't think it will adjust enough to throw the timing that bad though. :|
PostPosted: Fri Jun 22, 2012 6:37 pm
Can you borrow or buy a timing light and check it that way? Trying to get the ignition advance sorted blindly it probably wasting your time.
PostPosted: Fri Jun 22, 2012 8:52 pm
We have a timing light but the timing mark was wayyyyyy off. I read in my chilton that the knob is called the "octane selector". It also said that every graduation of the knob would be 10 degrees of crank angle and I have turned it a ton in both directions before I even knew what it was. Im gonna tinker with it tomorrow and see what happens. :roll:
PostPosted: Fri Oct 19, 2012 11:34 pm
:tu: :D AWSOME wagon!!!
<3 the purple painted wheels :tu:
 Post subject: Re: RT78 Corona Wagon Budget Build Thread(22re swap)
PostPosted: Sun Jul 28, 2013 8:51 pm
Got my 22re engine/trans swapped in today. been working on it about 2 weeks.
ermagherd no 8rc
fitting shifter. gonna chamfer the corners to make it look cleaner.
new mount
mocked up
 Post subject: Re: RT78 Corona Wagon Build Thread(22re swap)
PostPosted: Wed Jul 31, 2013 9:51 am
how did you get the front springs out. I tried a couple weeks ago and just couldn't figure it out, on top of the fact that I was scared that the spring would just shoot out and smash my face. did you have to use the compression tool or just unbolt a bunch of things.
PostPosted: Wed Jul 31, 2013 11:06 am
Little more work from yesterday
Modified/flipped crossmember(needs more tidying) and spacers
Spacers all welded up/smoothed/blasted. Ready for powder coat.
PostPosted: Wed Jul 31, 2013 11:11 am
I didnt use any special tools. I think I just unbolted the bottom A-arm from the spindle as well as the shock. Put a jack underneath the A-arm, unbolt, and let the pressure off slowly with that. Its been a while since Ive messed with it. Im rebuilding the whole front end soon so Ill prob have pics of it.
PostPosted: Fri Aug 02, 2013 10:15 am
Thinking about getting this(below) so I can run the factory speedo since the 22re/5spd has an electronic speed output. I assume that I will need the xcable with the 5/8 female output but not 100% on that yet. Anyone else had any dealings with these things?
http://www.abbott-tach.com/cablex.htm
Users browsing this forum: No registered users and 8 guests
