It is currently Sun May 03, 2015 11:03 pm
Post a new topicPost a reply Page 3 of 5   [ 97 posts ]
 Post subject: Re: Carina 1972 rebuilding
PostPosted: Sat Feb 02, 2013 4:19 pm
i wana see more more more that's fantastic man keep that work :tu: :tu: :tu: :tu: :tu:
PostPosted: Mon Feb 04, 2013 11:15 am
No problem. & thanks :)
PostPosted: Mon Feb 04, 2013 1:16 pm
Excellent work mate, like the others I'm impressed! You've got me looking at shed rentals now. And I have added lathing to my list of must have skills, well done sir.
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
PostPosted: Mon Feb 04, 2013 1:58 pm
Very impressive work, can't wait to see the end result!
PostPosted: Mon Feb 04, 2013 2:34 pm
Thanks. Yes a lathe is very handy for a car restauration. And the usual tools like MIG welder and so on.
First layer of line seed based rust protection is hammer- tight bonded on the steel. Greyish so it converts the rust particles into iron ore. Good stuff
Furthermore led some new pipings for brake and fuel. Used for fuel 8mm LPG gas fuel line. I don't want to get the carb bowls full of rubbisch from the old fuel lines haha
PostPosted: Tue Feb 05, 2013 10:38 am
My favorite kind of build thread! Awesome work! :tu:
PostPosted: Wed Feb 06, 2013 9:09 am
I enjoyed seeing this restoration! :tu:
PostPosted: Wed Feb 06, 2013 11:18 am
would love to see a write up on the radio.
great work man.
PostPosted: Thu Feb 14, 2013 3:33 pm
Did some blasting today, and 2nd layer of rust protective paint is painted on the bottom. Another 2 layers of thicker stuff are needed for perfect black underbody finish.
And can you imagine it was like this before.
When i look at the archiving photos, it scares allmost the hell out of me. :lol:
Glad with the results now.
PostPosted: Mon Mar 25, 2013 2:52 pm
Painted the underside with rust protective paint ( is with special agents and has anti chip properties)
Custom 3 point seat belt mounting point on body welded
PostPosted: Sat Mar 30, 2013 12:42 am
Looking good, quite a lot have been found at the front end.
PostPosted: Wed Apr 10, 2013 1:48 pm
Did some lathing on the allready light flywheel. I took the flywheel of my 2nd engine, a begin 1980 2T-B with recession in it, and only 10kg. Drillings made it to 7 kg, lathing 6kg
the moment of assembling has started!
Subframe :
Rear axle, MOT or not road legal yet...... springs are loose... :?
PostPosted: Sat Apr 13, 2013 1:17 am
flywheel is lightened to 6 kg. And Balanced:
http://www.youtube.com/watch?v=hhRQgbTg ... e=youtu.be
PostPosted: Thu Apr 18, 2013 5:21 am
Body on her own feet again!
Next week will start 2pack epoxy painting
PostPosted: Fri May 03, 2013 1:44 am
2 Pack high solid epoxy painted on outside. Has to harden out few weeks, then filled and plane-sanded.
With motorbay/trunk i have other paint plans
PostPosted: Wed May 15, 2013 3:37 am
Drilled holes for fendermirrors, and fitted fenders/bonnet to check the positions
Filling of laquer is proceeding
PostPosted: Wed May 15, 2013 9:25 pm
WOW fantastic!
Thanks for sharing
kolxoz
 Post subject: Re: My 1972 TA12 Carina project
PostPosted: Sat May 25, 2013 10:29 am
Filling and sanding..... The work by hand is the best, no machine flattens the surface that nice as a piece of wood and sandpaper. And checking surface is done by hand too.
Dont look @ the crappy phone pic distorsions..
PostPosted: Wed Jun 05, 2013 1:30 am
Thanks Matches & Kujala !
The original hood is painted in 2009 and refreshed the artwork by thourough cleaning and clear laquering
It needs about 10 patches to clear the rust on backside, frontside only 1 patch. The i have 2 hoods to swap on events and so on :)
PostPosted: Sun Jun 16, 2013 11:08 am
boot & motorbay sputterpainted, and body is completely filled and sanded, 2nd 2pack is on
Users browsing this forum: coronamx13, Google [Bot] and 3 guests
