It is currently Sat Mar 28, 2015 4:14 am
Post a new topicPost a reply Page 2 of 6   [ 103 posts ]
 Post subject: Re: My MX63 build
PostPosted: Tue Jan 15, 2013 1:44 pm
what kind of tracking do you intend to do with it?
PostPosted: Tue Jan 15, 2013 3:12 pm
I will be doing some drift days, autocross, and a couple fun road race days if we can get a big enough local group
PostPosted: Wed Jan 16, 2013 9:09 am
you're going to have plenty of fun with the stock na 2J mated to a manual transmission. take all the time you need to research and put together a good turbo setup while you drive it too.
PostPosted: Wed Jan 16, 2013 9:42 am
Even the 5m with a 5 speed will be fun. I plan on doing a few things to the 2j like a clutch and light weight flywheel along with an intake and exhaust so it will be a blast
PostPosted: Wed Jan 16, 2013 2:28 pm
if you're going turbo don't waste your money on intake stuff. you'll just be spending it again later and there's no aftermarket intake that will net you genuine gains that will be worth the money. don't do a header either unless you plan to stay NA. exhaust, might as well get what you want for the turbo up to the dp area and make it easy on yourself later if you can. have a shop make you a 3" pipe from there to the back and plan on your dp being fabbed to meet up with it.
PostPosted: Wed Jan 16, 2013 3:28 pm
The intake and exhaust are going road be required to get everything to fit. I am not gonna do a header unless I find a really good one for dirt cheap. As far as the exhaust goes I will do anything so its not to hard to hook up after I go turbo
PostPosted: Wed Jan 16, 2013 5:55 pm
When I did my 5 speed swap, my mpg went from 20 to 25, with a 240k mile 5M. If I had gone to 3.90 rear gears instead of the 4.10 used in the automatic, it probably would have been a lil better.
This is a link to my thread> '84 MX63 7MGTE swap
PostPosted: Wed Jan 16, 2013 6:16 pm
Nice, the auto does feel like it sucks a ton of power so the gas mileage bump is not unexpected. After running some numbers through the tire calculator the closest I can come is 225/50/15 so I am going to throw a 10.5 set steelies on the car and rivet on some flares to make all of it fit :)
PostPosted: Mon Feb 11, 2013 8:13 pm
Ordered some parts today, including my wheels, tires and front lip. Gotta wait for some more money to come in so I can order all my suspension stuff
PostPosted: Thu Feb 14, 2013 5:40 pm
My new wheels showed up today!!!! Did a quick test fit to see how much fender work I am going to need to do....and the answer is a metric ass ton but it looks like I may be able to get away with not buying fender flares. The wheels do look awesome and with some metal work the car should look a lot better. Now on to the pics
Rear View
Rear fender
Front fender
Front view
My tires will be here tomorrow and should be mounted up sometime Monday so once that happens I will throw the wheels and tires on the car and see where things sit again because I am headed to the shop Saturday to start working on my fenders.
PostPosted: Thu Feb 14, 2013 7:14 pm
wow hella offset! flares or are you going to pull the fenders?
PostPosted: Thu Feb 14, 2013 7:55 pm
Fender flares as they will be easier to do and then I can just cut the crap out of the metal underneath. All 4 will be 2.5" wide so they should just cover the wheels and tires
PostPosted: Fri Feb 15, 2013 4:35 pm
Tires made it in today, and should be mounted up by the end of the today. Here is a quick shot of the size difference between a pair of 15x10" wheels and a pair of 205/60/15 Falken 512's
PostPosted: Sun Feb 17, 2013 7:14 pm
More work was done today, got my Datsun front bumper on, found some different flares for the car so if anyone wants some 2.5" ZG Flares hit me up.
New front bumper
FLARES!!!!!!
Please dont mind the hacked up look of the flares as they are being built for a different rig. I will be changing a few things on the way that they sit but overall that is about how they will look.I will need a small spacer in the rear. let me know what you guys think
PostPosted: Mon Feb 18, 2013 1:27 pm
they look like a6 celica gts or mkii supra flares. am i off by much? regardless, haven't seen that kind of flare on an x6 but because of how boxy the body is it might work.
you went with the plastic hardbody bumper? why not chrome? how'd it bolt up?
PostPosted: Mon Feb 18, 2013 1:36 pm
The bumper is a metal one off a ~1984 Datsun/Nissian, skipped the chrome as I am going to be getting rid of all the chrome on the car when I paint it and this just makes for less work when I do that. It took very little work to make it fit. We pulled the old parking bench off and cut a couple holes in the stock metal front bumper which could have been avoided by cutting 4 tabs off the new bumper and then we just tack welded the new bumper in 4 spots and hit it with a little flat black paint. You are way off on the flares, they are from a Jeep but they have been cut up a good bit. I am headed to the junkyard here in the next couple days to pick up my own set so I can get to work on making them just how I want them.
PostPosted: Mon Feb 18, 2013 1:59 pm
haha! that's a first for sure. datsun bumper, jeep xj flares, you need a bmw lip spoiler and a volvo or vw air dam to complete the look.
PostPosted: Mon Feb 18, 2013 2:05 pm
HAHAHA, my VW lip will be here tomorrow, no joke. I just need to find a spoiler for the back and the body will be pretty much sorted other than shaving a bunch of stuff.
PostPosted: Mon Feb 18, 2013 2:38 pm
wangan style ae86 spoilers have been used on x chassis. they look not bad if that's the look you're going for. basically any 80's box style car that has a spoiler could work.
PostPosted: Tue Feb 19, 2013 5:52 pm
My new front lip came in today so that will be going on this weekend. Still working on a few ideas for the rear spoiler, and I need to get out to the junk yard in the next few days to pick up my flares, then its time to start cutting them up. Trying to decide if I want to fiberglass them or go some other route...
Users browsing this forum: Yahoo [Bot] and 1 guest
