It is currently Thu May 23, 2013 10:49 am
 Post subject: Brake Light Switch for 360?
PostPosted: Sat Nov 14, 2009 6:11 pm
Anybody know of a replacement? Mine has stopped working.
Thanks.
PostPosted: Sat Nov 14, 2009 6:33 pm
Photo? If you mean the switch on top of the pedal assembly, they are fairly universal.
PostPosted: Sat Nov 14, 2009 10:40 pm
yeah pull it out and take it with you to the yard...these are probably made by third parties like Mitsubishi and Hitachi anyway... check old japanese cars till you find something that will work...
Friends don't let friends drive stock. 8)
http://www.myspace.com/abandonaugust
PostPosted: Sun Nov 15, 2009 11:39 pm
It's a pressure operated switch that screws into the master cylinder.
PostPosted: Mon Nov 16, 2009 6:25 am
you might want to take it down to a place that specializes in volkswagon bugs and see if they have a replacement from like say a 1970 bug that would work in your application, if not I will see how my 76 is sat up like since I finally have my car at the house now
PostPosted: Mon Nov 16, 2009 4:56 pm
Oooo... Got one of those on my friend's Lotus 7. He hates it because it doesn't work very well while sitting at a stoplight. Not very safe.
I would strongly advise you to wire in a switch on the pedal. Easy enough to do...
PostPosted: Mon Nov 16, 2009 9:07 pm
if it is a real Lotus 7 then it would be the Dark Prince known as Lucas at play there for that situation lol
PostPosted: Mon Nov 16, 2009 10:10 pm
lol
I stongly agree with DF get you a decent mechanical switch.
PostPosted: Tue Nov 17, 2009 6:24 am
It's not. :P
It's a Birkin S3.
But I'd bet any car with a hydraulic switch is going to have the same problem. When sitting at a stoplight you aren't pressing on the pedal hard enough to activate the light.
PostPosted: Tue Nov 17, 2009 6:53 am
If you stick with the pressure switch try your local Motorcycle shop. Lot's of older bikes used them, mostly for the rear brake.
83' DR30
