It is currently Thu May 28, 2015 9:28 pm
Post a new topicPost a reply Page 4 of 6   [ 104 posts ]
 Post subject: Re: 1986 Subaru Leone STi Turbo
PostPosted: Wed Oct 16, 2013 8:25 pm
this is what the dash looks like with night vision on
so this is my new power level with working oil pump and front mount intercooler set up and the big s300sx FMW turbo on. so 21psi is safe for me, franz could have pumped more boost out but i need to get home to canada again just in case.
old plot with new plot dyno dynamics both on american 93 gas ( Canadian 94 gas will gain a bit more) next will try race gas which will bring the power way up and over the top because I have lots of room to play with... as of now its just insane to keep it all under control while I am on it, so baby steps on my part while driving and my a/c blows nice and cold to keep me calm lol.
so things I need to do are:
maybe bigger rad (brz koyo)
oil cooler
lots of braces, one for the diff and a H brace up front with strut brace.
PostPosted: Wed Oct 16, 2013 8:28 pm
I went to the track to try my luck and see if it all holds together this past week, after doing one pass on the q-mile and getting kicked off for no helmet ! I managed to pull a 12.6 out.
I know I know my times suck out the box ! I dont want to snap my axles or leave my Diff on the floor ! so I took off bogging in first and not revving out 2nd or 3rd gear becuase the car likes to lay rubber in the rear tires.
I am on the left Porsche 977 twin turbo on right... high boost button used
so after getting kicked off i went lapping to see how well the car handles ! scary move lol.... my brakes are to small or weak so maybe better pads, and the car feels like it needs some wider tires and bracing to help keep it more stable.
Low Boost On was used for lapping its to scary with high lol
as of now its fun to play with till i fix things out
[url="http://instagram.com/p/dlEgg1J4ps/?igref=ogexp"]http://instagram.com/p/dlEgg1J4ps/?igref=ogexp[/url]
well the season is done for me and I got out on the track a couple times more for fun to test out my new brake pad's, the pad's helped out a bit more but still need more work.
PFC 01 compound group N pad's work well very well, lots of dust but rather stop then not.
S203 S204 Spec-c Ra R oil cooler adapter factory from subaru oem has come in. built in thermostat opens at 100 C and OEM Made In Japan By STi no other adapter is better !
my spare earls cooler should do the job, got rid of A/C for this set up :( lol
I put the 86 Subaru Leone away for the season but next year to do lit will be fun.
wider sticky tires + smaller wheels 15"
Race gas tune 500hp DD it
better suspension stiffer springs
STi oil cooler
BRZ koyo rad install
i also was going to swap out my STi Spec-c 6mt 3.900 to my S204 STi 6mt 3.545, but its now in my winter beater (99 Nico). i think my winter beater will be more in need of longer gearing next spring when i do the motor swap.
http://forums.nasioc.com/forums/showthread.php?t=2558289
PostPosted: Sat Oct 26, 2013 10:25 am
well cooler bits arrived now got to figure out should i tap for threads or use hose and clamps system.
STi JDM Spec-C, RA-R, S204, S203, oil cooler adapter
PostPosted: Wed Nov 06, 2013 2:01 am
holy shit this car is cool!! :tu: great work man
PostPosted: Tue Nov 26, 2013 7:13 pm
lol thanks man glad you like my work so far :tu:
very excited about this radiator ! its a brand spanking new OEM Subaru 1988 Subaru XT6 2.7L H6 Radiator, its 2 core and also has the proper port size for inlet also outlet as a new EJ motors use.
it's also a perfect match to my EA82T turbo radiator, same size same width same cap location same mount points and also XT6 rad hoses to complete the job.
I wish I new all this from the start of the build, but it sure is going to be sweet next summer on the race track to do more laps in the heat, also the spal fans will bolt up in the same position as the gl-10 turbo mt rad. with the bigger radiator and my oil cooler this should complement the motor very well now.
and my new trunk seal which took a long time maybe it was made for me in japan but it came in also oem subaru for that perfect fit, i had a small rip in mine that i didnt like.
PostPosted: Thu Jan 02, 2014 1:23 pm
I been slacking on my updates, but most my parts are in for the spare EJ22T motor. i decide to get all new case bolts washers caps pretty much everything lol.
also got a new weather stripping for the hood, the original one had a small tear in it.
also picked up the original stickers for my rear doors, i have turbo on the door from factory but my car was a FWD not AWD... so i have to give it the subaru justice of the AWD.
PostPosted: Fri Jan 03, 2014 9:29 pm
and here we have 2 EJ22T blocks out of 9 cleaned and ready for the shelf for when the time comes, lets hope no more broken motors for 2014 season..
PostPosted: Fri Jan 03, 2014 10:07 pm
here is the spare EJ22T ill be using and its V9 JDM heads rods pistons all on a wheelie cart lol... this motor will get all the new plugs and JDM oil cooler.
PostPosted: Wed Jan 08, 2014 6:40 am
here is my water pump set up, this pump is for a non turbo Subaru "1990 Subaru Legacy 2.2L NA". There is a couple things special to this water pump which works perfect in my build. The black pipe is coolant heater core pipe single, and the hose adapter is H6 ez30
little back ground on the design
The EJ257 and EJ255 engines are using a low cost stamped impeller water pump that is inferior to this JDM spec closed back cast impeller water pump. The stamped impeller pump is less efficient and more susceptable to cavitation. We suggest installing a closed-impeller pump on any performance or motorsport Subaru engine build
so besides the cast impeller, the inlet port is huge which should help a bit more with coolant flow. on a turbo water pump there is 3 nipple ports... 1 oil cooler... 2 swirl pot... 3 heater core... now because I'm not using a swirl pot and have a rad cap on the rad I can delete that nipple port & the pipe all together.
also my oil cooler has no coolant going into it any more so that port can be deleted also, because of the use of the JDM spec-C S204 adapter.
PostPosted: Sun Feb 09, 2014 9:38 pm
is it summer yet ??
PostPosted: Sun Feb 09, 2014 11:18 pm
Put back to stock. :mrgreen:
PostPosted: Thu Feb 13, 2014 4:58 am
stock is not the jdm japanese way lol :D
my new momo prototipo steering wheel, its got that old vintage look
more boost with race fuel and a tune fore some real power.
PostPosted: Sun Mar 16, 2014 7:01 pm
got lots of parts coming in for my toy very excited to fix the little problems and add some new updated bits to make this car more fun a race track this year.
I found a nice GL-10 Turbo cross member from the local scrap yards had it sand blasted and powder coated black for that long lasting effect. also did the USMB washer weld on trick to re locate the control arms a bit further out so I wont have rubbing binding problems any more with the XT6 control arms.
here you can see the old hole with new hole
my spare Bosch 044 came in (might use this for my other build going on will see) and my arp head studs 625+ for the spare motor, still waiting for the new subaru crankshaft to come in from subaru japan to build the block which wont be much longer.
PostPosted: Mon Mar 24, 2014 3:32 pm
So I been collecting parts for my car now do to everything being Super RARE or no longer available (NLA) from Subaru any more.
just in case I bend something or I need to replace something, some of the stuff is still getting sand blasted and powder coated.
front control arms bushings XT6 only white line # W51458. you must melt out the XT6 bushing and re use the shell for this to work.
top corner in Pic is bushing and shell
there rear mustache bar on the older Subaru's also have a bushing that can be replaced with a white line part number # W91379. this part fits on all new Subaru's T bar holding the diff up. to make this bushing work you must burn out your old metal shell that the bolt goes into, then drill out the white line bushing to the same size as the bolt shell.
pic bushings is in center XT6 control arms you can see them.
there will be more bushing's coming to firm up the ride on my car, I need to measure them still and cross fit from a newer Subaru once all stuff comes in.
PostPosted: Tue Mar 25, 2014 7:56 am
today my Nolathane bushings came in for my Subaru XT6 control arms, for people that never heard of Nolathane, there the owner of Whiteline which is more popular in north america then in Australia but the boys down under know all this all ready lol.
Now I'm waiting for my other bushings from SuperPRO which should cover the rest of my underside bushings and give me that firm more responsive ride around the race track this year.
Nolathane # 46200
direct swap made with the shell
PostPosted: Thu Mar 27, 2014 5:02 pm
I got my 2015 Subaru Impreza STi shift knob, looks good in red match my horn button now.
PostPosted: Mon Mar 31, 2014 6:29 pm
here is the drain back for the dip stick for the Mann Hummel Provent 200 set up I have made... this is for a friend of mine which has a built Subaru also, same design as my original one I made for my Leone.
ill also be making a easy adapter for the inlet on the Provent 200, so its easy to connect the block vent and valve covers all in one tube with out making back pressure free flowing for better movement of air.
used a stand grinder then cleaned up with a file and deburring tool.
ill weld this up and paint it so it stays nice and clean rust free.
when building a subaru motor fuji bond or fixing the brakes RX2 grease and servicing the cv axles and cv boots you got the proper grease from subaru !
PostPosted: Tue Apr 01, 2014 4:46 pm
well I finished the welding the dip sticks for the return line for the Provent 200. I also made a adapter piece because I have had a couple say the pipes inlet are to big and hose will not fit this and that...
the pipe I made is for the block vent and both valve covers, came out ok should do the trick and not block as much air as T ing the tubes up.. more air you can move the better.
all the under side of a GL / XT / XT6 / Loyale sand blasted and powder coated to last a long time... Turbo cross member, XT6 arms front rear, XT6 20mm sway bar, XT6 5mt or 6mt cross member. I'm just missing the rear cross member which I need to find a spare to work with.
Whiteline & Nolathane bushings in place now got to do new wheel bearings and there done.
PostPosted: Thu Apr 03, 2014 3:42 pm
with the help of Franz @ DieboldAutosport he pointed me in the direction of Karim @ Lachute Performance for this Aim Fuel level adapter for a Subaru.
the Aim dash needed a converter to give it proper signal on a factory fuel sending unit. The sending unit is for the OEM subaru Analog dash in the 1986 ~ 1994 Subaru GL or Loyale, my Oem unit was a digital dash so it need to be changed to the different Ohm unit.
