It is currently Sat May 18, 2013 8:59 am
Post a new topicPost a reply Page 1 of 2   [ 31 posts ]
 Post subject: bonvos winter warrior
PostPosted: Tue Aug 23, 2011 4:41 pm
i just struck a deal for one of these
78 subaru 4x4 goon this isnt a pic of the one im getting just a general shot the one im getting needs brake and clutch work but it comes with 2 spare motors and 3 sets of tires including studs it runs like a top has some rust and needs a tail light lens but all in all a clean little goon pics will be up in about 2 weeks when i make my first payment
TacoDelRio wrote:
 Post subject: Re: bonvos winter warrior
PostPosted: Tue Aug 23, 2011 6:38 pm
Thats my photo of the wagon I had before my FF-1 :P
PostPosted: Tue Aug 23, 2011 6:58 pm
lol yeah its one of the few that i could find mine is tan with tan interior it runs great aside from the hot wired fuel pump the brakes are dead there is no fluid left in it same with the clutch im thinking that i could probibly get away with refilling and bleeding the systems its comming with 2 motors and 3 sets of rims and tires 1 bald set one good summer set and one good studded set
PostPosted: Tue Aug 23, 2011 8:06 pm
Might be leaking wheel cylinders or the master cylinder might need a rebuild too.
FYI, the E-brake is mechanically linked to the front calipers so you can always use that to brake the car in an emergency.
PostPosted: Tue Aug 23, 2011 11:05 pm
yeah ill figure it out nothing new done it before lol im gonna fill it and bleed it just to see what happens its been sitting since 04 and lit right up on the first try it did move on its own for 20 feet the right rear wheel was dragging in the gravel im thinking the drum has rusted to the shoes its gonna be a get it on the road and drive it thing not really a project its gonna be my winter warrior as the title states and maybe a little rally machine in the summer
PostPosted: Sun Aug 28, 2011 8:10 pm
keys are now in my hands picking the title up tomorrow and the car within the week
http://i70.photobucket.com/albums/i100/ ... 11755a.jpg
http://i70.photobucket.com/albums/i100/ ... 11755b.jpg
http://i70.photobucket.com/albums/i100/ ... 11755c.jpg
http://i70.photobucket.com/albums/i100/ ... 111807.jpg
pics would be embeded but jnc says there to big? there only 800x 600
PostPosted: Mon Aug 29, 2011 9:51 pm
well i now have the title getting the car some time this week hard to beleve 200 bones got me all this subi goodness
PostPosted: Mon Sep 05, 2011 9:47 pm
ok wtf jnc!!! i have resized all my pics to 640x480 and i still cant post them whats going on with this
PostPosted: Mon Sep 05, 2011 10:04 pm
I don't know, they've had some serious image posting issues the last couple months :|
PostPosted: Mon Sep 05, 2011 10:23 pm
its bugging me im able to keep all my threads up to date but this one
PostPosted: Sun Sep 11, 2011 10:05 pm
ok update time minus pics the car has a tach and brakes now i also have a clutch for it that is going in tomorrow
PostPosted: Tue Sep 13, 2011 8:46 pm
ok i dont know what is going on but jnc needs to fix the site!! i cant post pics ive tried resizing them and still nothing it makes it hard to keep you guys updated when i cant post pics
anyway i pulled the motor out and went to change the clutch with a used disk i got from a friend but it was the wrong disk so i now have a new clutch and head gasket set comming from rock auto
PostPosted: Tue Sep 13, 2011 10:40 pm
hey i dont know what you're doing wrong because i just made one of you pix appear ^
PostPosted: Wed Sep 14, 2011 7:06 pm
normally i post the [img] code from photobucket then when i try and post it complains that the image is to big i then resize it and it still says its to big
i just tried it again and got this in red across the top of the screen should i be using a different code? this is the same one ive been using threw out my 610 build so im confused
Your images may only be up to 800 pixels wide.
now keep in mind i have already resized my pics to be smaller then this
PostPosted: Thu Sep 15, 2011 12:15 pm
Check the file size?
PostPosted: Thu Sep 15, 2011 5:50 pm
i have checked the file size and i have resized it so that it will be happy with it even then it wont work i resize them to 600x400 thinking that since both dimensions are smaller then 800 it should work and it still doesnt
PostPosted: Mon Sep 19, 2011 9:11 pm
gasket set came in only thing it was missing was an oilpan gasket O_o valve seals everything and for 20 bucks cheap insurance
PostPosted: Thu Oct 06, 2011 10:27 am
im slacking clutch and head gaskets are done carb is rebuilt now i just need to un ghetto- rig the fuel pump and im ready to rock
first i painted the valve covers
and air filter
used a silver base coat and anodized blue paint
then i got really busy for about an hour O_o
end of the night
cleaning the head mating surface
dad prying out the valve seals
passenger side pistons
drivers side yes she needs a good seafoaming
torquing down the heads
assembled
the stair-down
proof i did more then take pictures lol
empty
up.......
......and in
running
video of the quiet valves before carb rebuild
http://www.youtube.com/watch?v=o5Ypl1tPDbM
threw the air filter on it to see how its gonna look
PostPosted: Mon Oct 17, 2011 11:31 pm
update
i got new snow tires on it and it developed a very bad vibration in the right front so i checked it out there was alot of play in the inner tirod and the axle had alot of play in it so i got out the spare axle and took it apart now im waiting on a new tierod tood the right front corner apart needs an axle (knew this ) grabbed the extra one that came with the car its the wrong one
also discovered that the bal joint is shot all of these things combined are what is giving me the vibration from hell so now i get to order an axle and a ball joint
PostPosted: Sat Oct 22, 2011 10:06 am
these are my dads 33's moar lift is needed this is with the car on jack stands set at the highest setting dad thought it would be funny to act like he was ran over
anyway new axle new ball joint and tie rod shes as good as new
