It is currently Sun May 19, 2013 11:17 pm
 Post subject: 1980s subaru, custom beam
PostPosted: Wed Sep 01, 2010 11:17 pm
thought I would share this. I hav a 1987 subaru, dual rnage. My neck of the woods breaks these like candy in the darndest places...just staying road worthy. :roll:
I found two beams that really needed to be there. I made some..
if you can decipher above, it gently meets the center carrier in the tunnel, and the square end is where the rear seat bolts go through...
the other end is this:
and here is another angle:
this has proven to fix every other error I welded. I am in 12 full mig reels, 2 pounds a pice.. and greater than 32 sq feet of sheet, and 4 spring steel rods.
I could have save alot of effort with these beams installed...your creaking sube is telling you something. :wink:
one final shot:
PostPosted: Fri Dec 10, 2010 8:43 pm
Thanks for sharing your work with us. So you added those beams to fix a creaking problem or was the car falling apart from rust?
Mike
'77 Datsun B210
'81 Datsun 210
PostPosted: Fri Dec 10, 2010 8:44 pm
I think it's great that Subaru ran the fuel and brake lines inside the car to keep them corrosion free. Nice!
'77 Datsun B210
'81 Datsun 210
