Finally, time to do stuff to my car.
I have been playing with the suspension and tension rods for ages to get it fit like i wanted it to fit, never succeeded.
And then i got an idea
I took of the oilpan, and did this to it:
filled it with water to test if it was leakfree:
and it was
Now i could place the anti roll bar were i wanted it to be, and make my tension rods.
I bought two of these:
angle grinded the std. tension rods in half, took a piece of pipe and welded it on the half tension rod with the uniball attached to the other end.
now they are a few cms longer then before and i can make a proper bracket for them and because of the uniballs i can adjust them too.
i ordered a big aluminium 240z radiator from ebay to solve the radiator issue, the std. one wouldnt fit anymore because of the inlet and outlet beinig in the wrong place.
i ordered an external fuelpump, and foam to put in the tank to prevent the fuel from slapping around.
i took off the std. fueltank and was a little bit surprised when i had it off.
there is the filler neck on the right side, the fuel pickup on top and two other pipes on the left side.
i look into the tank and the lower one of the two seems to be a pickup to, or maybe a return, there is a piece of pipe on the insede of the tank almost to the bottom of the tank.
the lower one just stops on the inside of the tank, leading to nowere.
both of them were capped of with a piece of rubber hose and a bolt in it, leaving them unused.
To be continued soon!
