It is currently Thu May 23, 2013 2:02 am
Post a new topicPost a reply Page 5 of 6   [ 112 posts ]
 Post subject: Re: My S130
PostPosted: Thu Apr 26, 2012 5:06 pm
UtahSleeper wrote:
Well, it is your car, so too each his own lol. Figured under 300 for a Megasquirt and an adapter and you would have been golden. That and you do tune with EFI, or atleast I do.
Mind you, not saying anything negative about carb's. Just not my cup of tea, so had to ask why remove efi for them.
lol everyone's car I know that runs MS runs like shit. No thanks. I had pretty much maxed out what the intake could flow as it was, anyways, so just throwing in different ignition/injector timing would have gained me zilch. Which brings me back to the $2k+ for the ITB's to make any extra power. (and all the ITB's available don't look as cool as SU's or Triples).
PostPosted: Fri Apr 27, 2012 9:44 am
I can understand wanting a certain look :) MS works for me and my car runs great, hence the reason I like it. I am also running aftermarket manifold and 70 mm TB, so thats going to give me diff performance when compared to an old stock setup.
Love your car and the work being done to it. Whats the next plan?
PostPosted: Fri Apr 27, 2012 6:17 pm
yee, and thanks dude! Right now I've got 14k springs for the rear on order. then I need to get new dampers for the Stance coilovers I bought and put those all in. directly after this, I'm getting my new wheels re-lipped. Going to 14's and super stoked on it!
PostPosted: Mon May 07, 2012 6:58 pm
http://www.youtube.com/watch?v=Yp7g_xUJwOI
PostPosted: Thu May 17, 2012 9:17 pm
http://www.youtube.com/watch?v=JqLpViCcLHE
PostPosted: Thu May 24, 2012 11:07 am
NyanCat
76' Datsun 280z
http://www.youtube.com/watch?v=IlOSJmyHPd0
PostPosted: Thu May 24, 2012 9:43 pm
what the hell have you done for that steering angle?
must. have.
PostPosted: Fri May 25, 2012 4:31 pm
heeeh
removed lock-nut on inner tie-rod (replaced with loctite) got about 2* angle
modded knuckles got the rest. I didn't even shorten them that much, everyone says I should have gone more, but I love where my angle is at currently, and I already rub the rear of my inner front fenders at full lock (feels weird as FARK in motion haha) even with my small ass tires (2" shorter than stock). And with a de-powered power steering rack with spacers and extended control arms I should achieve all the angle I could ever desire.
knuckles:
http://sphotos.xx.fbcdn.net/hphotos-ash ... 3197_n.jpg
notched control arms:
http://sphotos.xx.fbcdn.net/hphotos-prn ... 7149_n.jpg
suspension shit:
http://sphotos.xx.fbcdn.net/hphotos-ash ... 8437_n.jpg
Stock tension rods have been good so far, caster is even good at 5.8* so I'm not too hurried to get some T3 Tension rods
and here's my final static angle:
http://sphotos.xx.fbcdn.net/hphotos-prn ... 3054_n.jpg
PostPosted: Fri May 25, 2012 5:16 pm
is that the new location for u-drift? i need to go there. is third possible? i could run the whole track in 3rd when they were at lvms
viewtopic.php?f=17&t=22188
PostPosted: Fri May 25, 2012 6:32 pm
My friend Royce was entering 3rd in his Miater. I just have fun in 2nd gear, I feel bad for my trans when I smash downshift back into 2nd lmao
The course is pretty tight, I was doing about the widest lines you possibly can out there in that video.
PostPosted: Wed May 30, 2012 1:37 pm
Thanks buddy.
I've already removed the lock nut and added a small spacer for the steering rack, wa just curious how another S130 guy pulled it off. I figured you would have the knuckles from manual steering rack or something.
Finally, we'll be welding up these arms once we get my cage put in.
PostPosted: Wed May 30, 2012 4:08 pm
every knuckle from every type of steering rack is the same on S130s.
I've checked lol
btw my car came factory with the manual rack, still has the manual rack...
I'm looking to upgrade it to a power rack and de-power it so I can use regular S-chassis tie rods and shit.
I've already got an S14 rack rollin around, trying to decide if I want to try and make it work or not...
PostPosted: Wed May 30, 2012 9:02 pm
Why do you want to depower the s130 rack? What the big deal with s13 tie rods on that depowered s130 rack? Just curious to see where you're going with things. Figure I've been doing trial and error with everything else, why not see where other guys are going with their cars.
PostPosted: Wed May 30, 2012 10:01 pm
The reason why I'm depowering a power rack isbecause my car came stock with manual steering, and power steering is gay lol
The reason why I'm looking to swap to a 280ZX power rack is because S13 inners will work with it, allowing me to use S13 outers and also hopefully gain a little wheel clearance. S13 inners will allow me to use rack spacers, as well, to gain further steering angle
The reason I want to try and use my S14 rack is because it will let me use S14 solid rack bushings, and also use the PBM offset bushings to fix a little bumpsteer and change my ackermann a little, as well.
PostPosted: Sat Jun 30, 2012 10:00 am
PostPosted: Sat Aug 18, 2012 9:37 pm
test-fitting "new" wheels
http://sphotos-b.xx.fbcdn.net/hphotos-a ... 3448_n.jpg
16x12 -23
PostPosted: Sun Aug 19, 2012 8:30 am
Yeah! Get yer poke on! 8)
PostPosted: Sun Aug 19, 2012 10:57 am
these are actually ~3mm less poke than my current wheels lol
PostPosted: Sun Aug 19, 2012 12:05 pm
Shut the front door! Any closeups of your old setup, then?
PostPosted: Sun Aug 19, 2012 1:07 pm
this is about the most recent/relevant pic I have of my rear fitment:
http://sphotos-b.xx.fbcdn.net/hphotos-s ... 7795_n.jpg
