It is currently Sat May 25, 2013 6:36 am
Post a new topicPost a reply Page 3 of 3   [ 45 posts ]
Go to page Previous  1, 2, 3
PostPosted: Mon Nov 08, 2010 4:24 am
Ok, so now i own the 280C!!! gave it a clean up and will try to get some stuff for rego (exhaust) and see how she goes!
i wonder if there are air shocks/hydraulics for these?? hmmmm
actually just a set of lowered springs would be good...waaay too high!!
:lol: :twisted:
gimme all your cars!!!
PostPosted: Mon Nov 08, 2010 4:31 am
Well I'm glad it went to a good home, it deserves a restore.
PostPosted: Mon Nov 08, 2010 5:13 am
Actually came up quite good!! got rid of all the leaves and caked on mud under neath the arches, found the rear muffler is rusted out but is a 2pce so no probs there. just need to get underneath with a wire wheel and knock off the surface rust before rego. will order some points/cap and leads this week and it'll run good. (already put fuel cleaner thru it)
PostPosted: Mon Nov 08, 2010 5:28 am
I only drove it up the road and back (with no problems) but was told the auto was missing a gear. Be well worth servicing the auto and fitting a new filter just in case.
I've never had a car with a stuffed auto (even when the fluid was full of metal) as a fluid and filter change has always fixed things up.
By the way, do you want to sell your bus?
PostPosted: Mon Nov 08, 2010 5:37 am
seems ok, i will give it a service before regular use tho. replace all the oils etc and some hoses too!
msg sent re:bus
