It is currently Mon May 04, 2015 9:13 pm
Post a new topicPost a reply Page 25 of 27   [ 539 posts ]
Go to page Previous  1 ... 22, 23, 24, 25, 26, 27  Next
 Post subject: Re: Project Fade To Black-HR31 Skyline. Had a bit of a probl
PostPosted: Wed Dec 04, 2013 1:06 pm
Any news ?
PostPosted: Wed Dec 04, 2013 2:51 pm
It's at the repairers.
They can't get the bonnet open because the cable has melted and frozen and they don't want to damage the carbon bonnet.
PostPosted: Thu Dec 05, 2013 9:33 am
Ah, bugger. :cry:
PostPosted: Thu Dec 12, 2013 3:09 am
It's hanging in the balance at the moment.
Toasty.
PostPosted: Thu Dec 12, 2013 9:21 pm
Yurg, that looks nasty! Hopefully, a simple plug-and-play replacement elements to fix. Watching avidly. Neko.
The Black Cat - S800M Coupe.
PostPosted: Fri Dec 20, 2013 2:30 pm
The insurance company has written it off. Something to do with lifetime repairs and the age of the car.
I have bought the car back.
Because it is so old, the car does not have to be de-registered and does not show up at the RMS as a write off.
I got some quotes to do the loom and they were frankly a bit scary.
So in the spirit of this whole deal, and with nfi about electrics, I'm going to have a bash at it myself.
A mate of mine has an intact coupe that he has kindly offered me (with the exchange of some cash of course) so I can go and remove the loom from it.
That will be going into my car, and if it still doesn't go, then I'll call in an expert.
Work on my car starts today.
PostPosted: Fri Dec 20, 2013 5:43 pm
Glad you kept the car. It is only wires so a little tracing and splicing I am sure that you will get things worked out.
PostPosted: Sun Dec 22, 2013 6:03 am
crazy a wire harness ends in a write off. seems like such an easy fix. hope it all works out in the end
PostPosted: Sun Dec 22, 2013 12:18 pm
Solid progress made.
Battery out, grill out. Intercooler out, inner guard out, Oil cooler and lines out, autospoiler and motors off.
Had to go to a Christmas party.
Work resumes on Tuesday.
PostPosted: Mon Dec 23, 2013 2:16 am
Good luck with the repairs. Wiring can cause some major headaches, but I'm pretty sure you will succeed!
'90 N13 Sunny 1.6 GT - '00 P11-144 Primera 1.8 - '88 N13 Sunny 1.6 GTi - '00 Micra Aztec 1.3i
PostPosted: Mon Dec 23, 2013 5:04 pm
Me too :D
Made some solid progress this morning.
Loom out from Pass side indicator, washer bottle, across rad support, next bit is the fusable link block.
PostPosted: Mon Dec 23, 2013 8:30 pm
Got to here and decided Xmas eve.
PostPosted: Mon Dec 30, 2013 7:28 pm
Here is what I have learned so far.
The loom goes from the passenger side side indicator, across the front of the car, back to the fire wall and across that too.
Through a hole at the rear of the drivers side guard, across the car just under the front window, down past the ecu in the passengers footwell under the carpet and under the passenger seat.
It necessitates the whole dash and crashpad coming out amongst other things.
This is the full disaster pulled from a friends junker HR31 earlier today.
PostPosted: Wed Jan 01, 2014 4:53 pm
Okay, here is where we started the day.
To here
Because of this part of the loom
Almost half way.
PostPosted: Wed Jan 01, 2014 6:06 pm
OUT! all 8 metres and 87 plugs of it.
This means I am half way.
Actually past halfway because I've already taken the loom out of the other car.
PostPosted: Wed Jan 01, 2014 7:24 pm
Having another wiring loom at least should save you the agony of tracking down the inevitable "why doesn't it work" after replacement. At least you should be able to rely on the wire loom color coding insted of asking "which of these twenty black wires that I installed is the bugger?"
MikeRL411
PostPosted: Wed Jan 01, 2014 8:54 pm
That is a giant harness. You going to fix it or just put the other one in?
PostPosted: Thu Jan 02, 2014 3:29 am
Loving your decision to fix this beauty! :tu:
Well done on your work so far and best of luck with the re-install...
Best Regards,
Anders.
PostPosted: Thu Jan 02, 2014 3:40 am
I'm replacing the whole thing.
PostPosted: Thu Jan 02, 2014 11:06 am
did you figure out what caused the failure initially?
Users browsing this forum: Yahoo [Bot] and 3 guests
cron
