15th April 12
Been busy lately with lots of work and family commitments, but seems like project is back on track
Sent the car to Peak Performance Garage in Dubai few weeks back and finally they started working on it. I always loved their work, they did all the work on my 370z as well.
Work being done now and will be completed in next week or so:
Intercooler piping, will do weld joints once its finalized
Already changed the Radiator to another one ordered from CXRacing, its for 240z with an RB engine along with twin fan shround from flex-A-lite
Moving the Intercooler a bit to the front
Moving and flipping the oil cooler behind intercooler, as it was touching some body parts
Changing all hoses to new silicone hoses
Rerun the clutch lines
Rerun the brake lines to give a more neater look
Rerun the fuel lines from inside the car
Relocated the fuel pump inside the car
Changing differential mounts
Installing MSA front and rear sway bars
Installing/replacing all gauges with autometer ones
Installing HKS boost controller
Rest will update as it goes
Removed the stock fuel filter and cleaned up lots of things.
Can see the stock fuel line, piping will change now
Relocating the air filter near master cylinder
New Radiator, now hoses will run like stock RB engine bay, and better cooling, installed the flex-A-Lite twin fans along with shroud as before
Moved the intercooler
Moved the oilcooler behind the IC now
15th May 2012
