It is currently Sat Mar 28, 2015 9:19 am
Post a new topicPost a reply Page 6 of 6   [ 117 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6
 Post subject: Re: Derux DR30 FJ20ET
PostPosted: Mon Jun 10, 2013 9:22 am
DeRuX wrote:
So I have got a wiring diagram now. If any other DR or R30 guys need it here is the site that I found it on.
http://hr30.net/pages/wiringdiagrams.html
He uploaded the DR stuff this weekend for me. So after I get this printed I will dig in and find my problem.
Thank you, I needed this. Now to find someone to translate it.
'71 4 DOOR 510
'76 912E
'83 DR30 SKYLINE
'85 300ZX
'03 350Z TWIN TURBO
'07 MAZDA 3 HATCH
'09 ACURA RDX
PostPosted: Mon Jun 10, 2013 11:04 am
I am working on that.
PostPosted: Wed Jun 12, 2013 8:48 am
I printed out a large color copy and gave it to my one of my employees daughter to translate it for me. Maybe we can get together later and compare notes.
'71 4 DOOR 510
'76 912E
'83 DR30 SKYLINE
'85 300ZX
'03 350Z TWIN TURBO
'07 MAZDA 3 HATCH
'09 ACURA RDX
PostPosted: Wed Jun 12, 2013 11:12 am
Cool sent you a pm
PostPosted: Fri Jun 14, 2013 12:32 pm
Which part do you need translated? I can bang it out for you real quick. Have to support the other DR guys!
87' HR31 Skyline GTS Turbo
84' DR30 Skyline RS-X Turbo
85' Toyota Apex Trueno Liftback
65' Toyota Corona (Toyoglide)
85' Mazda RX-7 S
PostPosted: Fri Jun 14, 2013 10:42 pm
Alright I cleaned up and made one large image and then translated the ECU wiring harness diagram. I went ahead and added it below. I'll start on the DR30 chassis wiring diagrams tomorrow. I'm not sure if the export DR30s were different at all from the JDM ones but the below wiring diagram is for the JDM DR30 Skyline.
Click for the full size wiring diagram:
http://japaneseclassicimports.com/dr30wiring/FJ20ET_DR30_ECU_DIAGRAM.jpg
85' Mazda RX-7 S
PostPosted: Sat Jun 15, 2013 7:18 am
Dude you are crazy. Now what do I do with the one that I taped together. LOL
PostPosted: Sat Jun 15, 2013 11:47 pm
Good evening everyone. I finished the first page of the two pages for the DR30 chassis wiring diagram. I've cleaned it up a bit and translated everything over to English. It's a pretty big picture so you'll probably have to scroll around to get to the parts you need. This is the chassis wiring diagram for the JDM DR30 Skyline.
Click below for the full-size wiring diagram:
http://japaneseclassicimports.com/dr30wiring/DR30_Chassis_Wiring.jpg
Please let me know if you have any questions. I'll try to get started on the second and final page of the diagram tomorrow.
85' Mazda RX-7 S
PostPosted: Sun Jun 16, 2013 6:11 pm
Took car out today for a little drive around town. Worked great. The new front pads and rotors took the shimmy out of the front. My new seats feel awesome. The thing this car could use is a LSD. That would make it stick and stop all the one leggers when leaving the corners.
PostPosted: Mon Jun 17, 2013 8:38 am
Oh wow. Thanks Mason. Guess I won't need my translator any more.
Derux- do you have an open R200? I thought mine had an LSD. I have never had it opened up to look, but when I peel out both wheels spin.
'71 4 DOOR 510
'76 912E
'83 DR30 SKYLINE
'85 300ZX
'03 350Z TWIN TURBO
'07 MAZDA 3 HATCH
'09 ACURA RDX
PostPosted: Mon Jun 17, 2013 11:15 am
Ya mason has turned these things out.
I think mine is open cause when I turn the inside will just spin. I need to look at the diff and jack the car up and spin the wheels to check.
PostPosted: Mon Jun 17, 2013 5:06 pm
that's weird, i thought all dr's had lsd. i got lucky and my hr does. reminds me i need to change the fluid...i'm sure the drain and fill bolts are frozen on that f*<ker haha
PostPosted: Tue Jun 18, 2013 12:05 pm
Ummm, Hr's never had lsd's Maybe yours was swapped.
Also you might find that due to its age and how "weak the preload is" It will act like a open diff.
PostPosted: Tue Jun 18, 2013 6:21 pm
i know HR's didn;t come with one. my whole engine/drivetrain set up is basically out a s130 :wink: everything is swapped haha. about the only R30 things left is the suspension and body itself lol.
PostPosted: Sun Oct 13, 2013 10:25 pm
Sorry for the long delay on finishing the second page. Been pretty busy with a job change. At any rate, the second page of the JDM DR30 chassis wiring diagram is below. It's an even larger image than the first page so it's probably best to download it. Please let me know if I can answer any questions about the translation.
Link to full-size image of the wiring diagram:
http://japaneseclassicimports.com/dr30wiring/DR30_Chassis_Wiring2.jpg
I spoke with Reid a bit ago at the show in August and I'm going to try to do more technical translations from the DR30 out of the factory service manuals. I hope these wiring diagrams help!
85' Mazda RX-7 S
PostPosted: Tue Oct 15, 2013 4:09 am
nice! thanks man :tu: :tu:
PostPosted: Fri Feb 27, 2015 12:11 pm
It has been a while since I have done an update. The car has been at Z car garage getting some work done.
So far it has got a new fuel pump, new cat and a test pipe (for those between smog fun times), and the front struts have been completely gone thru. The stuff that was in there was a little worn out. Right now they are working on getting it to pass the smog test.
